Thread: FX-R + HH = Fire
Old 10-06-2012, 04:05 AM   #1
Status...ADDICTED!
ceedawwg's Avatar
Default FX-R + HH = Fire
Hi All,
HH 45T Expert 540, Tekin FXR, Turnigy 2200 2S Lipo and Losi TX/Rx and servo. Installed this combo in my home made chassis and had some issues when I ran it for the first time. First off, is the HH Expert too much motor for the standard FX-R? I installed the components exactly as shown in manual and checked my work many times over. Actually I used the included red wire instead of the blue one on the motor +. After a couple minutes of running around the floor the + and - Batt terminals on the FX-R went poof and burst into flames. It got hot enough to de-solder the batt terminals on the ESC as you can see in the pics. Is there something I am missing here?
Forgot to mention...the power cap was installed as shown in the manual, I cut it off thinking it had gone bad or shorted but the ESC just started glowing again when power was applied to it. And yes, polarity was checked probably 6 or 7 times so I am positive it was wired correctly.
ceedawwg is offline   Reply With Quote
Old 10-06-2012, 04:14 AM   #2
Default Re: FX-R + HH = Fire
did you use the power cap on +/- ???
SwampDawg is offline   Reply With Quote
Old 10-06-2012, 04:18 AM   #3
Not sure what was the issues but 45t expert dont draw too much power for the fxr. I'm running mine decased, solder post removed with some HH 30t's on 3s
AlexG is offline   Reply With Quote
Old 10-06-2012, 04:18 AM   #4
Status...ADDICTED!
ceedawwg's Avatar
Yup...across the Batt +/-...here is a pic
Old 10-06-2012, 04:22 AM   #5
okay.....the FX-R is rated @ 104 amps
battery too much for this esc??
Old 10-06-2012, 04:24 AM   #6
was the power cap on the right way theres a blue indicator mark on the bottom of the cap to point the right direction? it could have also been a bad esc.
catpwred is offline   Reply With Quote
Old 10-06-2012, 04:26 AM   #7
Status...ADDICTED!
ceedawwg's Avatar
Manual says 2S Lipo safe so not sure...Batt is Turnigy 2200 2S 35C
Old 10-06-2012, 04:27 AM   #8
Status...ADDICTED!
ceedawwg's Avatar
Ya I checked that...blue shaded side is - and that is where I put it
Old 10-06-2012, 04:28 AM   #9
the cap is on correct
Old 10-06-2012, 04:32 AM   #10
its lookin like more like u could have goten a bad esc get in contact with tekin let them now what happened and show them the pics of the clean wiring job u did they should make it right. ive had 2 bad esc's and they made it right i did get some help from the lhs but it was made right by tekin
Old 10-06-2012, 04:35 AM   #11
Status...ADDICTED!
ceedawwg's Avatar
Thx a lot for the input guys...I will get ahold of Tekin and see what happens
Old 10-06-2012, 06:49 AM   #12
Yeah...I don't see any issues with your install. Usually swapping the cap polarity causes it to fail, not the ESC.
High turn motors are almost never an issue, as mentioned the amp draw is down compared to a 35T or lower.
We're assuming the drivetrain is free, you didn't have it all bound up and not waaayyy over geared?
Charlie-III is offline   Reply With Quote
Old 10-06-2012, 06:54 AM   #13
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Contact Tekin. They can determine if it is warranty. Certainly looks like it is. Sometimes power electronics just fail out of the box, even with rigorous bench testing.
JohnRobHolmes is offline   Reply With Quote
Old 10-06-2012, 12:40 PM   #14
Status...ADDICTED!
ceedawwg's Avatar
High turn motors are almost never an issue, as mentioned the amp draw is down compared to a 35T os lower.
Everything is free with no binding, gearing is like 18/86 IIRC
Old 10-06-2012, 01:54 PM   #15
I figured you had checked everything...also figured you'd checked the drive train.
Just making for sure for the next person that actually does a search.
Let us know what Tekin says, as stated, your pictures seems to indicate you did everything OK.
Old 10-06-2012, 02:07 PM   #16
I have to agree....your wiring is sweet btw!
Old 10-06-2012, 02:13 PM   #17
I had a very similar thing happen with one of my fxr's. a On the second pack I plugged into it the fxr went poof up in magic smoke. The battery had been used before with no issues and I had already run 1 pack through the setup. As soon as I plugged the new pack in it smoked and took the battery with it!! Contact tekin theyy will take care or ya!!! They replaced mine no issues!!!
mammoth is offline   Reply With Quote
Old 10-07-2012, 08:57 PM   #18
sorry about the fire but i couldnt get my eyes off that amazing transmission.
sullivanscx10 is offline   Reply With Quote
Old 10-07-2012, 09:53 PM   #19
tell me about it!
i was thinkin on silver for my wraith but RED....NiiiiicE
Old 10-08-2012, 02:08 AM   #20
Not saying that this was the cause but could the cap not short out the +/- posts with it installed in that location? I would certainly think it is possible if it gets bumped and the housing (for lack of a better term) made contact with both posts. I would suggest putting the cap on the top side of the ESC where that is a non issue.
SMR 510RR is offline   Reply With Quote
FX-R + HH = Fire - Similar Threads
Fire slowrockr Colorado 50 06-27-2012 10:37 AM
Fire!!!!! The Violator Past RCCA qualifiers 11 03-31-2012 02:03 PM
Fire Fire Fire Lumpmister Chit Chat 7 06-25-2007 09:10 PM
I'm on fire!!!!! ColquittCustom405 Chit Chat 4 01-25-2007 04:09 PM
F1 fire up Scattman Chit Chat 1 04-24-2006 09:53 PM
