10-11-2012, 01:17 AM | #1 |
Newbie Join Date: Oct 2008 Location: Oakdale
| Venom pro charger false peak
Anybody else have this same problem? My venom pro charger always false peaks my batteries. I just add up where they leave off till it equals the batt. Capacity. Any experience and what is everyone's opinion on this charger? I like that it has so many different connectors and it does nimh lipo life etc. But wish it wouldn't false peak. I have a 3s 2200mah maxamps lipo that I've never used. Would a false peak and then start the charge over again be bad for lipo ?
10-11-2012, 01:30 AM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: Ireland
| Re: Venom pro charger false peak
Lipos don't false peak like nimh often does. If a lipo doesn't want to start charging there's a too low voltage detected on one (or all) of the cells. Check your LVC and all connectors. Lipo might be bad too.
10-11-2012, 04:56 AM | #3 |
Rider, I'm guessing it's not a false peak, you're hitting the 120 minute (2 hour) time limit. This can happen with smaller packs during a balance charge, so it's easier to do with a larger pack & balance charge. And no, it's not harmful to the pack to do 2 charges back to back. PS, we have 3 of these chargers, no false peaks but occasionally hit the timer. |
10-11-2012, 09:08 AM | #4 | |
Seven LiPos over the last 2-3 years, I can't ever remember having a false peak on LiPo. I'll assume you're either (as Charlie said) hitting the timer, or false peaking on NiMh/NiCad. Quote:
For LiPos, go strictly by voltage. Individual cell voltages should never, ever exceed 4.2 volts. And there should be zero heat during charging. | |
10-11-2012, 01:33 PM | #5 |
Thank you everybody for the good in formation. My lipo batteey ismt false peaking. I haveent ever charged it . I was just expecting it to false peak when i did charge it because i thouggt if was a charger issue. Good to know it wont though.
10-11-2012, 03:10 PM | #6 | |
| Re: Venom pro charger false peak Quote:
NiCD/Nimh was, "Charge to peak, hit a few more times to get the entire pack warm JUST before a race!" A warm battery gives MUCH better performance initially (it's a chemical reaction to release power), thus the "warmth thing". LiPO is a slightly different animal...... it does not tolerate heat as well as the "older chemistries". Yes, a "hot cell" in a NiCD/NiMH pack means it's ready to die, time to break out the soldering iron. PS, rider618.......how the fawk do you say it's "false peaking" if you've never charged it?????!!!!!!! | |
10-11-2012, 05:57 PM | #7 |
What is this guy talking about?
10-11-2012, 07:22 PM | #8 |
| Re: Venom pro charger false peak I (east coast), you (west coast) have no clue....maybe someone from the midwest knows?? Maybe a clue here??...... no torque at all "Is it bad if the pack shrinkwrap is split???" Last edited by Charlie-III; 10-11-2012 at 07:26 PM. |
10-11-2012, 10:32 PM | #9 |
Charlie I never said my lipo was false peaking. I said my nimhs were. I said I figured it was a charger problem and I assumed that when I do charge my lipo for the first time, I assume it will false peak. I think the battery got so hot from charging that it got brittle on cool down and then split.
10-12-2012, 04:54 AM | #10 | |
Thanks for clarifying. Do you have a temp probe for the charger? I know mine do, use that as well to help prevent overcharging the pack. No, it's not an issue to charge a pack multiple times, basically just hit "start charge" again just to be sure it's full. What charge rate do you use? I typically just use "1C", thus a 2200mah pack charges at 2.2Amps, a 1300mah pack charges at 1.3Amps. I use 1C for all my chemistries. | |
10-12-2012, 10:03 PM | #11 |
I charge all my batteries at 3.5 amps. I have always thought a slower charge would be a better charge but maybe since my nimhs are 5000's, maybe 3.5amps is too slow. Maybe that's why my batteries are getting so hot. I have heard of that too.....what you do....2200 mah/ 2.2 amps.......3500 mah/3.5 amps....etc
10-12-2012, 10:57 PM | #12 | |
Venom pro charger false peak - Similar Threads | ||||
Replacing fan in lipo charger - Venom Pro Charger | iamsuperbleeder | Electronics | 11 | 04-04-2012 08:06 PM |
Venom Pro AC/DC charger | Santee Creeper | Electronics | 3 | 04-12-2010 12:04 PM |
Venom pro charger | scram8 | Electronics | 3 | 05-16-2009 03:01 PM |
Pro-peak charger??? | DeaDShorT | Electronics | 3 | 07-22-2007 10:08 AM |
959 false peak problem/question | 72Blazer | Electronics | 4 | 05-05-2006 04:45 PM |
