10-12-2012, 05:07 PM | #1 |
Newbie Join Date: Aug 2012 Location: usa
| Need Help PLEASE!
Ok I have a traxxas tq 2.4ghz 4 channel controller, a rc4wd bulldog 9300xt winch. I would like to make the 4th channel middle position a so called dead spot. so when i hook the winch up it does not move in that middle position. what do i have to do to make that happen. any help would be appreciated.
10-12-2012, 06:31 PM | #2 |
| Re: Need Help PLEASE!
Is it a 3 position channel with 3 position switch?
10-13-2012, 12:29 PM | #3 |
no its a 4 position channel with 3 position switch.
11-12-2012, 05:54 PM | #4 |
after thinking about this for a while, i believe you are right. it is a 3 position channel but its the fourth channel on the traxxas tq2.4 4channel radio. however it is a 3 position switch. any help would be greatly appreciated
11-12-2012, 06:24 PM | #5 |
Rock Crawler Join Date: Dec 2011 Location: Las Vegas 89110
3 pos is already ready to go if thats what the 4th ch is on the traxxas remote....plug it in and go...there is a lil flathead screw on the winch controller to center it if it is moving on you when you plug in and power up
11-12-2012, 06:39 PM | #6 |
after a quick search the 4th ch on the tx is not a 3pos switch, it seems it can be modded to a true 3 pos switch or you can buy a controller to work with whatever the 4th ch is on there. hope it helps. google search traxxas 2.4g 4ch as a winch and you shall find the info |
11-12-2012, 07:09 PM | #7 |
If it's a 2 position switch, contact HeyOK (possibly LosiKid as well) on an adaptor that will work with a 2 position switch. Both are here on RCC as vendors. |
11-13-2012, 02:13 AM | #8 |
Pebble Pounder Join Date: Mar 2012 Location: Pacific north west
For some reason the 9300 stock controller don't have the dead spot even with a 3 position switch. It will drift no matter how you adjust the center position. Mine changed to hayok winch controller cured the winch drift problem. FYI.
