10-14-2012, 11:36 AM | #1 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
| Castle link help.
I have a problem with Castle link cant get program my bec or my brand new micro sidewinder. Im running windows 7 and google chrome. I think my driver is installed properly but im not sure i have the right usb cord, but any mini usb should work right? I have tried 3 different cords. But on every one i plug in when i connect the link it gets really hot and i quickly unplug it. why? and if it dosnt get hot, both colored boxes stay red... please help. Caleb |
10-14-2012, 12:07 PM | #2 |
| Re: Castle link help.
Yep, any USB cable will work. Do you have the PC board plugged in correctly? By the 3 small pins on the PC board (that go into a BEC or ESC) there is a polarity marking on the board, make sure it matches what you're plugging into. The "-" on the board should be going to the black or brown of the device you're connecting to. To do an installed ESC or BEC, you "may" need to plug a battery pack in since the Castle link can't power up multiple devices at once. |
10-14-2012, 12:14 PM | #3 | |
| Re: Castle link help. Quote:
10-14-2012, 03:20 PM | #4 |
Sounds like it might be a bad Castle Link. You shouldn't have any batteries connected to the BEC or the ESC when you plug them in. They should automatically show up when you plug them in. I like to start their app first, then plug in the ESC/BEC to the link, then plug USB into the laptop. |
10-14-2012, 04:40 PM | #5 | |
10-15-2012, 04:58 AM | #6 | |
If they're wired together (dual ESC's, ESC & BEC, dual ESC's & BEC) you may have to plug a battery pack in (as I mentioned earlier). | |
10-15-2012, 06:48 AM | #7 |
Rock Crawler Join Date: Jul 2012 Location: Long Island, NY
I start Castle Link, plug USB into board, plug battery in, plug board into device needing programming.
10-15-2012, 07:38 AM | #8 |
I always unplug the device from the receiver and plug it into the programmer then into the computer. Charlie, what do you mean by connected together? I have my dual Sidewinders in my truck and they are connected to motors and the battery leads are connected together. All I need to do is unplug the lead from receiver and connect to programmer. |
10-15-2012, 08:45 AM | #9 | |
10-15-2012, 08:47 AM | #10 |
10-15-2012, 08:51 AM | #11 |
| Re: Castle link help. |
10-15-2012, 12:22 PM | #12 | |||
Sometimes it works if I unplug from the RX and plug in the Castle Link, sometimes I need to plug a pack in. Both ESC inputs & BEC input are all common to a single battery pack. That SUCKS... Quote:
Do you have anyone local that can help test?? | |||
10-16-2012, 09:02 PM | #13 |
I don't have any locals to test :(
10-17-2012, 07:43 AM | #14 | |
So, it works for me because I don't remove pins. Makes sense now. | |
10-17-2012, 07:58 AM | #15 |
Quarry Creeper Join Date: Jul 2012 Location: Alpharetta, GA
I was having a problem programming a BEC and noticed that it was trying to power the ESC as well through the battery side of the connections, it never would detect on the computer and the light on the link stayed red. I think someone may have already mentioned this, but worded differently. I never though of plugging in the battery to program, what I did was put plugs in line on the battery input of the BEC where it splits off from the main plug. When it comes time to reprogram anything I unplug the BEC from the battery leads and everything works fine. |
