10-14-2012, 04:33 PM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| waterproofed the electronics.. truck stopped working
used corrosion x on the esc, and receiver .. used plastic dip on the servo.. fell down a little hill into a 2 feet of water.. hit the trigger by mistake.. wheels wee spinning. get back up nothing. servo worked.. uplugged it real fast... soo what the hell happened this time? |
10-14-2012, 05:00 PM | #2 |
| Re: waterproofed the electronics.. truck stopped working
Pull electronics, shake out water, decase if "easy", pack in a container with uncooked rice. Seal the container and let rest for a few days. Unpack & see what happens. |
10-14-2012, 06:30 PM | #3 |
Newbie Join Date: Apr 2012 Location: winnsboro
I have tried the rice idea on other electronic items. It has worked well for me in the past, I wish you the best with getting your crawler back in order.
10-14-2012, 07:10 PM | #4 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
Happened to me last time out, truck stuck in deep hole and then stop working, I shake all the water out from motor, turn the wheel a few time to spin the motor. then everything work again. I played with it another 15 min no problem. Since you servo work, I am guessing your RX and servo is fine, remove your motor and dissemble and clean it. Its most likely fine, of course you can check it with another ESC or power supply. The esc, check if you have a weakness is waterproofing, the un-cooked Rice trick mentioned above works wonder. Try it. |
waterproofed the electronics.. truck stopped working - Similar Threads | ||||
axial ae-2 stopped working | RootBreaker | Electronics | 4 | 07-17-2012 04:59 AM |
CC BEC just stopped working | Kraqa | Electronics | 5 | 01-30-2010 02:18 PM |
Stopped working, AGAIN | *xj-man* | Losi Mini-Rock Crawler | 14 | 04-23-2009 08:56 PM |
Stopped Working... | *xj-man* | Losi Mini-Rock Crawler | 8 | 04-09-2009 04:55 PM |
Stopped Working!?!?!?!? | Z71HULK | General Crawlers | 8 | 01-16-2006 10:20 AM |
