Motor install, connectors or hard wire ? I'm going to put a Novak Goat 3s in my nightcrawler and Tekin FXR with a 35T in my Honcho. My question is whether to hard wire them or install bullet connectors to the motor ? I know hard wired is the least resistance and no chance of corrosion but with high quality connectors the voltage drop should be almost zero. I like tearing stuff down alot and it's nice to be able to disconnect the motor. Anybody ever have and serious problems using connectors ? |
Re: Motor install, connectors or hard wire ? Go with some good plated connectors. I use them and know others that do. Can't go wrong especially when it comes time to tear things apart. |
Connectors, makes things a lot easier. I use 4mm bullet connectors (females on the ESC side). |
Re: Motor install, connectors or hard wire ? Yep I use 4mm bullets on all my crawler motors. For go fast I solder it direct though, less junk to go wrong. |
Re: Motor install, connectors or hard wire ? I use 4mm Castle bullets as well. |
Re: Motor install, connectors or hard wire ? Connectors weigh more, add resistance, and become another point of failure. I stick to direct wire. |
Re: Motor install, connectors or hard wire ? Quote:
Re: Motor install, connectors or hard wire ? Direct wire. Easier than connectors and less to fail. |
