10-16-2012, 02:52 PM | #1 | |
Rock Stacker Join Date: Feb 2012 Location: Israel
| Servo Powered Straight Off Battery Question
Originally this question was asked in another thread but I thought It is better placed here. Anyway, I plan on buying a Hitec HS-7954SH servo. Now I want to power it (obviously), but I don'y quite know how. Here comes my first question, on a receiver, the port that says b/c (battery right?) provides the voltage of the battery? Can I plug in any motor and it will run on 7.2 volts? (for example) I was told I can power the servo straight off the battery this way: Quote:
That way I don't need a BEC right? But now the servo will receive 7.2 volts straight from the battery, is it OK for it? Thank you very much for your help! yorai | |
10-16-2012, 03:05 PM | #2 |
Pebble Pounder Join Date: Jun 2012 Location: Canada
| Re: Servo Powered Straight Off Battery Question
Your RC has 2 power systems. A motor system, and a rx/servo system. The motor system might be 3s(12v), 4s(16v), 6s(24v), or higher. This voltage is to high for na RX/Servo. A BEC steals power from your motor system for the RX/Servo. This is done via either an internal BEC in your ESC (ESC is part of the motor power system) or is a seperate item (external bec) . The BEC included in most ESC is going to operate at 5v, and maybe supply 3amps. This is plenty for general applications in RC. Crawlers are not general. The big wheels jam up and need more torque to turn them. That torque is not free, it costs either speed (gearing) or it costs wattage (amps x volts). An external BEC can help supply the increased voltage and amperage to actually used by the 7954 you are considering. It runs at 50% more voltage (7.4vs vs 5v) and can draw more amps. |
10-16-2012, 03:20 PM | #3 |
That's a good point, but considering I'm running a 7.2V Ni-Cd battery this is actually a good voltage to run the servo on (isn't it?).
10-16-2012, 03:53 PM | #4 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
yes most voltage you should run through a servo is maxed at bout 7.4 for a safe voltage........bob .... |
10-16-2012, 03:59 PM | #5 |
Rock Crawler Join Date: Mar 2011 Location: hampton
the nicd will be 8+ volts charged though. get a BEC or a HV servo and know it will be safe, or try it and see if the servo will handle the voltage
10-16-2012, 04:02 PM | #6 |
Your servo might like it, if its rated, but most RX don't like anything above 5 or 6v. Its common to use the ESC BEC to power the RX, and then have a high torque servo run off a different voltage via BEC through a bypass. In theory you could run the bypass directly off the battery since its the right voltage. You would have to do some creative soldering/wiring from your battery lead. With nitros, the rx/servo system is fed directly off a nicd battery. |
10-16-2012, 09:42 PM | #7 | |
| Re: Servo Powered Straight Off Battery Question Quote:
Or just tie it in as you outlined in your original post and see how long it flies. | |
10-16-2012, 10:01 PM | #8 |
7954 is rated to run off 2s, mine has no issue with my CC BEC set at 8.4. A BEC is kinda a waste unless you switch to 3s Lipo, I'd say your plenty safe to power off the battery.
10-16-2012, 10:58 PM | #9 |
You are buying a $80+ servo and you are still running stick packs? Time for an upgrade!
10-16-2012, 11:34 PM | #10 |
Thanks everyone for your great responds. I think I will power it straight off the battery, as I heard some people even run it on 9 volts. And another question, when you talked about the BEC placement, is it between the battery and the servo or between the receiver and the servo? Thanks |
10-17-2012, 12:05 AM | #11 |
First the Rx: - The "battery" connector on the Rx mentioned in the first post is there to attach battery power to the Rx (when the Rx is used for something that isn't battery powered). The rest of the connectors are then used for servos or similar stuff. - The power feed pins on the Rx connectors are all internally connected in parallel, so it actually doesn't matter which "channel" connector is used to provide power to the Rx, and all other can be used to draw power. The Servo: I use the very same servo, happily feeding it off my 2S LiPo. It pulls 4A peak and 2A typical at that voltage. For convenience I'm running that extra feed through a two-pole switch that use one pole for the +V battery voltage to the servo, and the other pole replaces the little switch on the ESC. This way the servo is powered on and off at the same time as the ESC. The 0V line to the servo can go through the Rx, but there are some weak cables so I've added an extra cable straight to the battery here too, and it goes to the Rx as well to keep that voltage stable. For even more convenience I'm using colour coded mini-Deans to hook all parts together. When I switch to a higher voltage battery it's simple to add a separate BEC in serial with the brown mini-deans. |
10-17-2012, 03:33 PM | #12 |
That's a great setup!! Thanks for sharing! But what's the white wire that comes out of the ESC? |
10-17-2012, 03:42 PM | #13 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
motor wires i assume
10-17-2012, 04:02 PM | #14 |
He has it taped off. Thats the third wire used on brushless motors. the MMP, sidewinder, and their micro versions, are brushed and brushless type ESC's. I never understood why people paid so much for Castle, until i got my sw micro's and castle link... |
10-18-2012, 12:02 AM | #15 |
| Re: Servo Powered Straight Off Battery Question |
10-18-2012, 01:19 AM | #16 |
Pebble Pounder Join Date: Nov 2011 Location: Livermore, Ca
Invest in one of these bad boys . Make life easier . And they are only 5$ Can be found here along with the info needed http://www.creationfab.com/product/6...s-Adapter.aspx His username on the forum is: Chris_the_battery_man "Thumbsup" |
10-18-2012, 01:32 AM | #17 |
No prob dude. I'm actually running a pair of these on my XR and my wraith. It just makes it so damn easy and keeps for a clean wire job. Really well built too, deff worth the 5$ to have your BEC ran directly to the servo and to have the BEC powered straight off the battery . I just used a mini style dean off the batter leads and boom. Quick disconnect incase you change the voltage on the BEC |
10-18-2012, 05:23 AM | #18 |
Looking good! But isn't that cable like a mini Y harness with rewiring?
10-18-2012, 08:22 AM | #19 |
Yeah it's similar to a Y harness , but its wired to run power from the BEC straight to the servo, without cutting any wires or soldering. From there the sensor wire (white) and the ground plug straight into the receiver . It's a plug and go system. Check out the website I listed and read the description might explain better than I can
10-18-2012, 11:55 AM | #20 | |
Servo Powered Straight Off Battery Question - Similar Threads | ||||
Powered by Gens Ace LiPo Battery | hobbypartz | Vendors Market | 7 | 04-18-2011 03:46 AM |
AX10 Opitiona Battery/servo tray question | goldmember | Axial AX-10 Scorpion | 0 | 01-07-2009 01:51 PM |
battery/servo question | aint scared | Electronics | 7 | 09-01-2006 11:41 PM |
SERVO BATTERY QUESTION | Fishmaxx | Electronics | 6 | 08-11-2004 06:46 PM |
