10-17-2012, 10:07 AM | #1 |
Rock Stacker Join Date: May 2011 Location: Northglenn, CO
| De casing my Mamba Micro Pros
Hello all, I have been thinking about de casing my Mamba Micro Pro's, is there anyone out there that have done it and can you give me a idea of how to do it. Thanks in advance |
10-17-2012, 10:44 AM | #2 |
Quarry Creeper Join Date: Nov 2009 Location: Central Arkansas
| Re: De casing my Mamba Micro Pros
What are you needing help with exactly? It's a pretty straight forward process. Take the case off, then separate the heatsink from the board. Just use a small flathead and pry up slowly making sure you aren't damaging anything on the board.
10-17-2012, 11:01 AM | #3 | |
| Re: De casing my Mamba Micro Pros Quote:
Is it the same for MMP's as it is for other ESC's? | |
10-17-2012, 04:06 PM | #4 |
I'm not saying this is the best way but this may help you. How to decase remove heatsink from your esc / speed controller |
10-17-2012, 10:04 PM | #5 |
Thanks bro
10-17-2012, 10:32 PM | #6 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
You can also decase and leave heatsinks. Just gently bend caps away from sinks until the sinks mesh together. I was worried about our high temps here so I left them on. |
10-18-2012, 02:03 AM | #7 |
RCC Addict Join Date: Jun 2009 Location: Australia
A better way to remove the heat sink is use a heat gun and a pair of long nose pliers and a vice or clamp. Once de cased hold the esc in position to hold steady in a vice lightly or a clamp just to stop it moving around, but be gentle. Then using a heat gun apply heat to the heat sink area only, it may be worth sheilding the wires so as not to melt the insulation on the wires. Once you have heated it up, with a pair of long nose pliers gemtally pull upwards on the heat sink, you should not need force. It should just pop off. If it dosent or feels still glued re apply heat and then try again. Prying off with a screw driver can damage the components if the glue is set extra hard. It wont always but could cause dmage to the board prying it off. Remember when using the Heat gun it does its job well and heats up the vice and surrounding areas or the heat sink and will be hot to touch. Let it cool a little befote touching with your fingers. Ben |
10-18-2012, 05:39 AM | #8 |
Pebble Pounder Join Date: Jun 2012 Location: Canada
If you want light, why not go with sidewinder micros. No case already,very minimal design and cheaper. Seem to have lots of pop to them to, even with my current cruddy battery, and buttery smooth low end with my team brood 35t.
10-18-2012, 09:14 AM | #9 | |
Thanks for all the input guys, it's a big help. | |
10-18-2012, 09:16 AM | #10 | |
I am following your build thread for your "Thing", it's what I am building, (at least trying to build anyway). LOL. | |
