10-17-2012, 10:17 AM | #1 |
Pebble Pounder Join Date: Sep 2012 Location: The Middle Of No Where
| Traxxas Xl5 odd problem?
So i picked up a wraith that came with this esc..it powers on fine no problem like that... But when i go full throttle forward it just does not have very much wheel speed...but hit it in reverse it and spins as fast as it should anyone have any ideas? |
10-17-2012, 10:51 AM | #2 |
| Re: Traxxas Xl5 odd problem?
Did you try to recalibrate the ESC to the radio? What radio are you using? |
10-17-2012, 11:14 AM | #3 |
| Re: Traxxas Xl5 odd problem? |
10-17-2012, 11:22 AM | #4 |
RCC Addict Join Date: Jul 2011 Location: Orlando
Switch the motor leads..... If black is on black switch it to the other color and see if that helps.
10-17-2012, 12:28 PM | #5 |
Pebble Pounder Join Date: Nov 2011 Location: Muskoka, Ontario
The same problem happened to me, when powering on the esc I must have hit the button twice or something and it stoped working. I recalibrated it and found it was going faster in reverse, so I calibrated it again and that did the trick. Check and make sure your throttle adj. are set in the middle or slightly more, the axial tx isn't exactly a precision instrument.
Traxxas Xl5 odd problem? - Similar Threads | ||||
odd problem | CantonAreaCrawler | Redcat Crawlers | 15 | 09-21-2012 05:03 AM |
traxxas xl5 problem | mudd_slinger | Electronics | 7 | 03-02-2012 08:14 AM |
traxxas xl5 esc problem | axelman | Electronics | 12 | 08-28-2011 11:28 AM |
Traxxas xl5 esc problem | hunna122 | Electronics | 4 | 08-01-2011 03:27 PM |
Very odd Glitch problem | Skullbasher | Electronics | 10 | 10-24-2009 01:08 AM |
