10-20-2012, 06:13 AM | #1 |
Newbie Join Date: Apr 2012 Location: Morwell Vic Australia
| Traxxas TQi Transmitter
Hey Guys I just bought a Summit and I had to replace the ESC as the one supplied was faulty. I fitted the replacement and everything fired up OK. I have all functions. My problem is now the indicator lamp on the TX when first switched on glows green for a couple of seconds then one red flash and then continuously flashes green. I can't access the menu funtion on the TX at all. The truck seems to drive ok although (I think) that the throttle and the steering doesn't seem smooth. I'm new to the RC truck scene (I'm into helicopters) but I'm severely bitten with the bug. I hope that someone can shed some light on this issue. Thanks in advance. I love this forum guys, there are some seriously great trucks on here. Cheers Bill |
10-20-2012, 06:41 AM | #2 |
Pebble Pounder Join Date: Jun 2012 Location: Canada
| Re: Traxxas TQi Transmitter
You can reset the radio to default, and bind it again. You might have a stuck button on your TX, putting it into programming mode or something goofy. Or it could be your throttle trims. http://traxxas.com/sites/default/fil...-LED-codes.pdf Based on that the red is it binding, and the flashing green indicates "Throttle Trim Seek Mode" play with the trim knob. |
10-20-2012, 08:59 AM | #3 |
Pebble Pounder Join Date: Aug 2012 Location: Reno NV/ Palm Coast FL
Are all functions working?
10-20-2012, 04:09 PM | #4 |
Hey Guys Thanks for your replies. All functions are working Ok although, as I said, the throttle and steering feel a little twitchy. This may be normal but I wouldn't think so. I have tried several times restting the radio to default and I have re binded twice all with same result. I tried the multi function knob many times and it does nothing. It is just annoying that I can't access the menu to do anything. Maybe I should fit a Spektrum receiver and bind it to my DX3 What are your thoughts?? Thanks again guys Cheers Bill |
10-20-2012, 07:07 PM | #5 |
I still use my TQ with my scx10 and stampede. If I had issues, I would just buy some FS rx for $6 each and use the GT3B I have...
Traxxas TQi Transmitter - Similar Threads | ||||
Anyone Using the New Traxxas TQi 2.4GHz 4 channel? | cannaert | Electronics | 9 | 07-20-2014 03:00 AM |
Traxxas tqi not calibrating with my tekin fxr | motakitty | Electronics | 6 | 04-18-2012 11:16 PM |
traxxas 3ch tqi | rawpwr7 | Electronics | 2 | 03-07-2012 03:33 PM |
Traxxas transmitter mod | Kanine38 | Newbie General | 5 | 02-21-2010 03:17 PM |
