10-21-2012, 01:25 PM | #1 |
Rock Stacker Join Date: Nov 2010 Location: Roanoke
| T-maxx Converted
Ok like the title says i converted my T-maxx extended chassis to electric, i am running the Toro SC120 esc (which is awesome) and an Orion 3750kv brushless motor, (which is the quesiton) after about 5 mins of running on my 2s lipo the motor is pretty warm havent taken a temp but prob close to 180 or 200! like i said pretty warm. I was wondering how to get away from this, should i go to a lower kv motor or what? Any Input will be greatly appreciated! Thanks |
10-21-2012, 01:29 PM | #2 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: T-maxx Converted
Is the esc temperature ok?. Try a bigger pinion if you can.
10-21-2012, 01:34 PM | #3 |
Yes the esc temps are great, really cool to the touch, love this esc for the money! so you think a bigger pinion will kepe the motor heat down! Just makin sure thats what you meant because when i used to run crawlers with brushed motors the bigger the pinion the hotter the motor would run! I will try a larger pinion if i can find one(i think im running a 24t 32p pinion) thanks
10-21-2012, 01:34 PM | #4 |
Rock Crawler Join Date: Apr 2009 Location: Pa
A bigger pinion will just make the motor hotter. You wan to go smaller vs bigger. If you are running a 24t drop down to around an 18t just to see if the motor temps drop, which they probably will.
10-21-2012, 01:36 PM | #5 |
Thats what i was thinking! Going smaller will also down my speed right! I like the speed it has now and the bottom end torque is great. Do you think maybe running a longer can motor with a lower kv would help or would i want to run a higher kv?
10-21-2012, 01:38 PM | #6 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| Re: T-maxx Converted |
10-21-2012, 01:39 PM | #7 |
The T-maxx is a decent sized heavy truck so a lower KV would be better. Something designed for an 1/8 scale. I am no brushless expert but if I wanted speed and torque I would be looking at a 1/8 scale under 3000 kv motor and run it on at least 3s. Gear down, volt up.
10-21-2012, 01:46 PM | #8 |
well im gonna try that, and ill prob be running 4s when i get a new motor! got my new lipos on order now! hopefully find a motor to stick on this thing soon!
10-21-2012, 01:47 PM | #9 |
| Re: T-maxx Converted Found this. SKYRC TORO SC120 120A ESC & 4600KV Brushless Motor for 1/10 Car with Program Card Specifications: - Model: TORO S3663 4 Poles KV4600 Brushless Motor - Rotational Speed: 4600 KV - Motor Dimensions (Diameter x Length): 36mm x 63.4mm - Shaft Dimensions (Diameter x Length): 5mm x 15mm - Input Battery Types: NiCd/ Nimh/ Li-po Battery - Recommend Model: RC Model Car - ESC Specifications - Model: SC120 - Dimensions (Length x Width x Height): 55 x 37.6 x 38.4mm (2.17 x 1.47 x 1.5in.) - Continuous / Burst Current: 120Amp / 760Amp - BEC Output: 6V 5Amp - Resistance: 0.0004Ohms - Controls: Rev/Brk or Fwd/Fwd - Status LED: 1 with 3 color (Red, Green & Orange) - Thermal Overload Protection: Yes - Weight (without wires) 87g (3.07oz) Motor Limits: - Brushless KV<=6000: Up to 2S (8.4Volt), idel for 1/10 short course - Brushless KV<=4000: Up to 3S (12.6Volt), for 1/10 buggies and short course - Brushless KV<=3000: Up to 4S (16.8Volt), idel for 1/8 buggies With a <3000 kv motor on 4s that truck should be stupid fast. Invest in a wheelie bar. Last edited by dkf; 10-21-2012 at 01:49 PM. |
10-21-2012, 01:51 PM | #10 |
Quarry Creeper Join Date: Nov 2005 Location: Louisville, KY
I'm running 4s and a Dewalt 14v motor on my converted 3.3 T-maxx. Speed isn't like a brushless E-maxx or anything but the torque is ridiculous.
10-21-2012, 02:04 PM | #11 |
Thanks alot dkf! Ill try and find a motor here soon and get some video up! might try it as an Foff! Not sure but we will see! Thanks alot everyone for the help!
T-maxx Converted - Similar Threads | ||||
t-maxx converted to brushless | Jstalker | Traxxas Crawlers | 6 | 06-22-2009 05:13 PM |
My converted go-fasts | Cloak | Non Crawler RC's | 26 | 02-17-2008 11:06 PM |
t-maxx tranny converted 2 auto shift emaxx | O1rngredge | Traxxas Crawlers | 5 | 04-11-2004 06:45 AM |
