12-02-2006, 11:19 PM | #41 |
Newbie Join Date: Nov 2006 Location: L.A
the airtronics 94358 is a great servo. iuse them in my 8 scale buggy and my truggy. im on my second racing season with the same servos. they have a pretty good torque rating too. but for my crawler, im planning on using a 1/4 scale servo
12-06-2006, 04:13 AM | #42 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Well under the recomendation of a fellow crawler I met at the R/c expo a while back. I decided to go with a Hitec 5955mg. Heres why.
12-06-2006, 04:29 AM | #43 |
I just went with two MG5955TG's plus they can hold a 6 cell pack 471oz @ 7.2v...
12-06-2006, 01:03 PM | #44 |
Didn't know you could do that with these, I thought it was only with the 5995mg robot servo. Cool |
12-06-2006, 05:26 PM | #45 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
was running 645's not enough. went to towerpro 995's little better. still not enough. it is fot the price..
12-06-2006, 06:11 PM | #46 |
Pebble Pounder Join Date: Mar 2006 Location: hillsboro
I run a super class clod with LST tires on 3/4" ace adapters to 3/4" maximizer rims and did the following. Tried the hs645mg and broke the gears, then went to tower pro 995's and they had good power. They did not last long either, on the front the idler shaft wallowed out the front case and bound up the motor. The rear started doing the same and also starting glitching and hanging up. Bottom line digital servos are good for the super class, as long as you can adjust them correctly. With a quality digital transmitter that can adjust end point adjustment, or you will just burn out the pot? You wanna smoke your pot? I didn't think so. I went with Sysco's 1/4 scale servo mounts and used cs80's, and they get the job done with the use of my cheapy tq3. 1/4 scale servo, 30 some odd bucks and provides 343 oz. of torque. Enough said. Last edited by flexmonger; 12-07-2006 at 10:48 AM. |
12-07-2006, 04:42 PM | #47 | ||
12-07-2006, 07:12 PM | #48 |
I'll probably just run them off the super rooster anyways just to be safe.
12-07-2006, 10:21 PM | #49 | |
Quarry Creeper Join Date: Oct 2004 Location: illinois
If someone could make some metal output gears for the cs-80, I would reward them handsomely, since I've sheared off both output shafts off mine, and I bet my truck won't hesitate to do it again. | |
05-01-2007, 07:19 PM | #50 |
Newbie Join Date: Apr 2007 Location: Milwaukee
Mnster, how is your HS-5955TG? I need a replacement for my 645MG.
05-01-2007, 08:26 PM | #51 |
They are holding up great, still like new. I actually liked them so much I upgraded my TLT as well. Worth every penny. |
05-01-2007, 11:05 PM | #52 |
Im still beating on mine. They are my favorite (5955 or 5995)
05-02-2007, 12:09 AM | #53 |
Rock Crawler Join Date: Jan 2007 Location: Long Island NY
i have a 5995 in my revo takes a beating and still wants more |
05-02-2007, 12:26 AM | #54 |
RCC Addict Join Date: Feb 2007 Location: sweden
I stripped a pair of 5645 servos in 2 days, the same gear always failed, now im going to try airtronics, a bit more expensive but if they work its worth it!
05-02-2007, 06:39 AM | #55 |
Good to know. Keeping a 5645 in the rear, debating whether or not to use a saver, but probably not. If it strips, I'll just get another 5955! |
05-02-2007, 06:50 AM | #56 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
Been running 5955's in my Super for almsot a yr now. I can't say a thing bad about them. Strong and reliable |
01-03-2008, 07:19 PM | #57 |
Newbie Join Date: Nov 2007 Location: Owasso
Does anyone have any experience with Futaba's BLS351? It's the new brushless, Hi-speed, Hi-torque servo. 210 oz @ .13 sec.
03-20-2008, 05:03 AM | #58 |
Newbie Join Date: Mar 2008 Location: Northeast
Had the 3305 for years, no problem, New Gmade with Hitecs' busted one, Put the 10 year old 3305 on, broke 3 arms, not the servo.. then busted the other Hitec,, bougth the Latest JR with 400 rating.. Question is, Will it burn more elec up with the more torque? (Before I get a second for the rear) |
03-20-2008, 06:50 AM | #59 |
Quarry Creeper Join Date: Jan 2008 Location: marysville
x 3. Jr's z9000t is badass. That beast is running 6.5V in a Scorpion. HAHA I should have got it sooner. Finger breaker |
09-19-2008, 05:34 PM | #60 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
anyone use a Hitec 7990 333oz torque at 6v , 403oz of torque at 7.2 volts they also offer programmable fail safe Thinking of upgrading from 5955tg |
