10-24-2012, 11:42 AM | #1 |
Pebble Pounder Join Date: Nov 2011 Location: Muskoka, Ontario
| Hitec hs646wp acts funny @ 7.4V
I've got a 646wp that i've been running off a sr300 and tekin fxr. I decided to install a cc bec for the servo but when the voltage to the servo goes over 6volts it acts funny, the servo is knotchy and is slow to come back to zero, almost like it's sticking. I have the bec wired correct, red wire from fxr pulled and bec added to bind slot in my sr300. When I remove the bec the servo seems fine,when running the bec @6.0v its better but not perfect-anything over 6.0v it acts up. Has this happened to any one before? Could I have a bad bec?
10-24-2012, 12:50 PM | #2 |
Rock Crawler Join Date: Nov 2011 Location: Paradise, ca
| Re: Hitec hs646wp acts funny @ 7.4V
Nevermind i got info mixed up
10-24-2012, 01:19 PM | #3 |
| Re: Hitec hs646wp acts funny @ 7.4V |
10-24-2012, 07:06 PM | #4 |
I think Spektrum sometimes has issues with BEC's plugged into the bind port unless the signal wire is pulled from the BEC. The Y harness method of bypassing the rx also works around this.
10-25-2012, 10:37 AM | #5 |
Rock Crawler Join Date: Aug 2007 Location: Casper, WY
I run my bec through my Spektrum receivers also. I have them programmed at 6.8v but I run a capacitor in either the bind or the aux port. Mine would act up also with decent to high-power servos plugged in. Have you isolated it by trying a different servo? I ask because, for me, it was a Spektrum thing, not a servo thing. |
10-25-2012, 02:29 PM | #6 |
10-25-2012, 08:21 PM | #7 |
10-27-2012, 01:03 PM | #8 |
Newbie Join Date: Jun 2012 Location: bangalore
plug the current wires from the bec directly to the servo and let only the signal wire(white/yellow not the red n black) come from rx . and reinstall the red wire n othrs coming from the esc into the rx. that way u have two bec being used. one for rx and etc , one only for steering servo . solved my glitching problem , sr300. ;)
10-27-2012, 01:10 PM | #9 |
| Re: Hitec hs646wp acts funny @ 7.4V Definitive wiring diagrams for BECs Rx Servos Motors etc. last or second last diagram of the first page helped me solve my problem |
10-27-2012, 08:48 PM | #10 | |
| Re: Hitec hs646wp acts funny @ 7.4V Quote:
Oh and when the bec was installed in the wraith(flysky-xl5-7954) I hooked it up both ways, but not in the honcho(fxr-sr300-646wp)only red wire pulled on esc method.??? Last edited by Dualdigger; 10-27-2012 at 08:56 PM. Reason: additional info | |
10-27-2012, 09:01 PM | #11 | |
10-28-2012, 01:16 AM | #12 |
i have no experience with the xl5 but wont the internal bec of it be damaged by running 7954 which consumes lots of power. i have read somewhere in this forum that if the servo torque is more than approximately 200oz/in u need external bec. |
10-28-2012, 06:15 AM | #13 |
Pebble Pounder Join Date: Jun 2012 Location: Canada
If you bypass the RX and connect all your grounds it will work. One of the things lacking in those diagrams is a 3 way ground between rx, bec, and servo. I had glitching until i did this.
Hitec hs646wp acts funny @ 7.4V - Similar Threads | ||||
XL-5 acts stupid when in a bind | dolphenwulf | Electronics | 3 | 08-30-2012 09:06 AM |
Random acts of kindness........... | TNCrawler | Duratrax Cliff Climber | 25 | 01-15-2010 09:52 AM |
Funny hands-free video (TRUE but funny) | TLTCrawlin | Chit Chat | 2 | 07-17-2008 02:52 AM |
