10-25-2012, 04:02 PM | #1 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Dead Motor Any Ideas?
Got a bad motor any ideas what could be the problem? It worked last time I ran it but now it wont run, gets hot fast and smokes from around the brush hood. They only thing I did since it was last ran was take it apart to clean it and switch the wires to the posts on the other side(not on the same side). The arm turns free in the can with no binding and the bearings spin fine. Have tried... hooked it up to the front esc. swapped out the arm. changed brushes. hooked it up to the break in ps. Any ideas what else to try or what could be wrong? Thanks... |
10-25-2012, 05:12 PM | #2 |
| Re: Dead Motor Any Ideas?
My guess is: Conductive crap between comm segments You are connecting to the same pole/brush hood (you stated this is not so). These are the only things that are "can" related. You have changed everything external to the motor. |
10-25-2012, 11:25 PM | #3 |
Rock Stacker Join Date: Mar 2012 Location: longview
Solder touching can.? Loose magnet? Are any screws or spring post touching ring that holds the brush hood on?
10-26-2012, 12:26 PM | #4 |
| Re: Dead Motor Any Ideas? Nope still can't see what the problem is. Acts like it's shorted out though, maybe something I'm just not seeing. I tested the hoods with the brushes out and got an open line so I don't think the hoods are making contact with each other.
Dead Motor Any Ideas? - Similar Threads | ||||
Dead motor? | St33v3 | Team Losi Comp Crawler | 10 | 05-29-2012 03:32 AM |
Motor Ideas & motor soldering ??'s | WestTxRc | Losi Mini-Rock Crawler | 8 | 11-02-2011 07:03 AM |
motor dead? | ctrwannabe | Electronics | 8 | 11-07-2007 01:46 PM |
Dead Motor | SMR4RUNNER | Electronics | 2 | 05-21-2006 04:17 PM |
Dead Super Brain-and ideas? | Highmark | Electronics | 3 | 02-15-2005 10:31 AM |
