11-05-2012, 11:27 AM | #1 |
Pebble Pounder Join Date: Dec 2011 Location: Denver
| Exceed maxstone 10 ESC in a Wraith ?
hey all, noob question, but will a exceed maxstone 10 ESC, work on my stock axial wraith ? Is it a plug and play ? I did a quick search, but got to get to an interview. |
11-06-2012, 06:54 AM | #2 |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: Exceed maxstone 10 ESC in a Wraith ?
been running one out of a Mad Crawler in my SCX10 on 3s with no problem. not sure if there the same ESC. give it a try on 2s should work fine |
11-06-2012, 07:08 AM | #3 |
I don't see any specs on the ESC from a few vendors. The stock rig uses a 7.2vdc NiMH pack, so I agree, you should be able to run a 6 cell NiCD/NiMH or 2S LiPO (although you won't have a LiPO LVC built in). As to "plug & play", depends on your connections. The RX connection is likely fine and you can always change motor & battery connections if need be. |
11-06-2012, 08:12 AM | #4 |
very nice, thanks for the replies.. I should have one shipped out today. NOOB question, whats meant by 32 or 2s ? Im guessing something about the batteries ? |
11-06-2012, 08:35 AM | #5 | |
| Re: Exceed maxstone 10 ESC in a Wraith ? Quote:
Some packs may have a "P" which is where the cells are paralleled, this adds the capacity, not the voltage. Thus a 2P pack is ~3.6volts but doubled capacity (mah). For NiCD/NiMH a single cell is usually rated @ 1.2volts. Thus a 6 cell NiCD/NiMH is 7.2 volts. Last edited by Charlie-III; 11-06-2012 at 05:56 PM. Reason: Added info re: "Meaning of 'S'" | |
11-06-2012, 08:37 AM | #6 |
thanks Charlie, that was easy enough even I understood, lol |
11-28-2012, 09:56 PM | #7 |
Quarry Creeper Join Date: Nov 2012 Location: Blue Ridge
Ok, i just bought me a max stone 10. So the above writing means i CAN run a 2s 5000 mAh battery with my stock esc????
11-29-2012, 09:49 AM | #8 | |
Keep in mind, I see nothing that shows this ESC has a LVC (Low Voltage Cutoff), so it's possible to drain a LiPO too far down. If the directions with the ESC don't mention a LVC or that it is "LiPO compatible" I would suggest you find a "LiPO low voltage alarm" or "external LVC" to use. LiPO packs really don't like to get run way down. All my crawling ESC's have a LiPO LVC built-in, so I have no experiance using an external one. | |
Exceed maxstone 10 ESC in a Wraith ? - Similar Threads | ||||
my new exceed maxstone 10 | davidyack | Newbie General | 5 | 06-24-2012 11:48 PM |
exceed maxstone 8 | stanmondz | General Crawlers | 8 | 04-23-2011 09:10 PM |
Exceed RC MaxStone | prostock | Superclass Crawlers | 2 | 05-24-2010 11:05 AM |
