11-08-2012, 08:44 PM | #1 |
Rock Stacker Join Date: Dec 2010 Location: Oviedo
| esc problem no throttle control
my novak rooster crawler just started givin me trouble it will only give me power in one direction and it is full power i have no control, it was working fine then during a drive it freaked and started doin this, i thought it was the motor goin bad but i replaced the motor and it has the same problem. different batteries didnt help, please help im lost with this thing!!
11-08-2012, 09:41 PM | #2 |
| Re: esc problem no throttle control
First thing to try is to calibrate the ESC to the RX. If that dosen't change anything, try plugging the steering servo into the throttle channel and see if the trigger (throttle & brake) control the servo. If so, then the TX & RX are OK. If not, check throttle EPA's & trims, they may have been bumped. |
esc problem no throttle control - Similar Threads | ||||
Throttle control | Rich h | Axial Wraith | 8 | 11-16-2011 03:15 PM |
throttle and turn problem | mudn_1 | Electronics | 3 | 12-01-2010 06:23 PM |
having problem with throttle? | lildjloop | Axial AX-10 Scorpion | 17 | 04-28-2009 02:22 PM |
throttle problem | octigonwallrus | Electronics | 5 | 09-10-2006 12:56 PM |
