11-09-2012, 11:53 AM | #1 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
| RC4WD Bulldog 9300 Problem? HELP! so ive had my bulldog for about a yr now and i love it, but my recent rig has been my heaviest at just over 9lbs so ive noticed after use of my winch a couple times but not a full spool maybe 2ft-3ft it comes loose from the base that holds it, then gets some play forward and backwards i can wiggle it, anyone else have this issue? i dont wanna ruin my mounting stubs on the winch by pulling out the screws what can i do? any suggestions? ive tried the serchy button but i came up with nothing but vague results and when i get specific i get zero! |
11-09-2012, 12:00 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: RC4WD Bulldog 9300 Problem? HELP!
So did the winch actually pull free from the base and now the holes are loose? Sounds like you might have stripped the threads
11-09-2012, 07:26 PM | #3 |
Newbie Join Date: Mar 2011 Location: bismarck
The spool comes loose? locktight?
11-09-2012, 08:00 PM | #4 |
Exactly like that, they seem to back out and it comes free a little off the base and it has play im tired of having to remove the base to tighten the winch screws its a pita Sent From Outerspace Using my HTC-Freeze Ray Gun |
11-09-2012, 08:23 PM | #5 |
I would say loctite it and let it cure overnite. If it still comes loose, email customer service. There might be housings available but Im not sure for certain.
11-09-2012, 09:12 PM | #6 |
That sounds smart but I can't even get em tight I thought they would ne a little better quality than this Sent From Outerspace Using my HTC-Freeze Ray Gun |
11-09-2012, 09:45 PM | #7 |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
It sounds like the threads stripped out. You could try loc-tite 638 it's a bit thicker then the norm and has a better holding force. You have to figure after a year of use it doesn't sound like a quality issue, the strain on the screws holding it to the base has to be pretty high under load and are just getting worn out. Good luck with it --Dan Last edited by sickcivic95; 11-09-2012 at 09:49 PM. |
11-09-2012, 10:47 PM | #8 |
I don't use my winch much, maybe 8x since I've owned it thats why I would say quality is in question but I have no idea what this could be should I use different hardware? Has anyone had this same issue?? Sent From Outerspace Using my HTC-Freeze Ray Gun |
11-11-2012, 12:53 PM | #9 |
Bump anyone..? Sent From Outerspace Using my HTC-Freeze Ray Gun |
RC4WD Bulldog 9300 Problem? HELP! - Similar Threads | ||||
Rc4wd Bulldog 9300xt Scale Winch PROBLEM! | raiders32 | Electronics | 17 | 01-30-2014 10:17 AM |
Rc4wd Bulldog 9300xt Scale Winch PROBLEM! | raiders32 | Axial SCX-10 | 11 | 04-27-2013 08:26 AM |
rc4wd.... Bulldog 9300 XT wireless winch | OCMike | General Scale Talk | 10 | 08-29-2012 09:10 PM |
rc4wd bulldog 9300 help..??? | joenitro | Electronics | 8 | 05-27-2011 09:09 AM |
rc4wd bulldog 9300 winch problems | V3500 | Electronics | 5 | 03-03-2011 04:44 PM |
