11-09-2012, 01:30 PM | #1 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
| 9300xt
In the midst of a local build off at the LHS and Im curious if 1) the 9300xt is powerful enough to capably pull a 5ish lb truck comfortably and 2) can you run it on a seperate 2S (Although I imagine theres no LVC). \Thanx for any info |
11-09-2012, 01:54 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: 9300xt
Completely lifting your truck might prove a bit much, but used as intended will be fine. I ran 250mah 2s packs on mine with no trouble and it barely pulled any mahs after repeated pulls, so the lvc isnt a great concern.
11-09-2012, 02:10 PM | #3 |
Rock Crawler Join Date: Dec 2011 Location: Las Vegas 89110
| Re: 9300xt
i ran the 9300xt wired for a bit and always seemed to work fine. like erin said if you use it how its meant to be used then shall be fine. i tested mine dead lift with a fully loaded ae sc104x4 sc truck and other items and held fine. as for the 2s id imagine it would be fine but i only ran through the rx @ 6v 1 batt for whole truck.
11-09-2012, 04:18 PM | #4 |
| Re: 9300xt
I wasnt looking to "completely lift" the truck as much as repetedly use the winch for what its intended to do. I didnt want to buy/install a winch that was gonna quickly blow the motor or strip the internal gears of it. As far as the 2S - The thought of running a secondary small 2S for the winch made sense as when Im done building my SCX she will be powered by a 3S and I would imagine 1 of them would fry up the winch
11-09-2012, 05:16 PM | #5 |
| Re: 9300xt
Honestly if you looking for hardcore winch work a servo winch will suit you best, otherwise under moderate use, our winch will be good.
9300xt - Similar Threads | ||||
RC4WD 9300xt Winch | AsILayDying | Electronics | 10 | 10-06-2012 07:18 PM |
need help with bulldog 9300xt winch | demonut | Electronics | 4 | 08-22-2012 08:13 PM |
How do you like your Bulldog 9300XT Scale Winch? | TJ Steve | Electronics | 8 | 04-17-2011 05:54 PM |
bulldog 9300xt wireless question | mineARC | Electronics | 0 | 02-14-2011 10:02 PM |
RC4WD Bulldog 9300XT Winch | Grumpster1980 | Electronics | 3 | 04-22-2010 10:22 PM |
