11-09-2012, 04:36 PM | #1 |
Quarry Creeper Join Date: Mar 2012 Location: Montreal
| Servo plugs without tools
Hi everyone, I need to shorten my Servo wire and I would like to install a new plug. I have looked on youtube for how to and they all use a crimping plier. Do you have a way to make them without one (soldering etc...) or an idea to replace this plier? I know it is not this expensive but I would only use it once a year (And the electronic shop is quite far from home Thanks! |
11-09-2012, 04:53 PM | #2 |
Rock Crawler Join Date: Dec 2011 Location: Las Vegas 89110
| Re: Servo plugs without tools
the super easy way would be fold the wire and ziptie what kinda new plug |
11-09-2012, 05:05 PM | #3 |
When I shortened the wiring on my comp crawler I put the new plugs on with some plain needle nosed pliers because my lhs was out of the crimpers Sent from my SCH-R530U using Tapatalk 2 |
11-09-2012, 06:08 PM | #4 |
Moderator Join Date: Jan 2004 Location: chicago
get a ziptie, loop all the slack in the wires together, then ziptie it.
11-09-2012, 06:10 PM | #5 |
You could do it with a set of small needlenose pliers....but dont expect the connection to be perfect or last a long time if you are installing and removing it often.
11-09-2012, 06:16 PM | #6 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
If you crimp it with needle nose pliers and then solder it....it would hold up pretty well. If you have a soldering iron of course.
11-09-2012, 08:25 PM | #7 |
How about this... assuming you can get your hands on a soldering iron and some basic hand tools. No crimping needed! Remove the screws from the bottom of the servo and expose the circuit board. Put a little heat from your soldering iron on the three wires where the servo cable gets soldered to the circuit board. Do it one at a time and remove the wires. Cut off the amount that you need to shorten it and solder them back onto the circuit board. |
11-10-2012, 12:34 AM | #8 | |
Quarry Creeper Join Date: Feb 2011 Location: Las Vegas 89121
| Re: Servo plugs without tools Quote:
11-10-2012, 06:16 AM | #9 |
Thanks guys! This is for an XR10 and a very narrow chassis (switch), I placed everything with zipties but this looks like a mess, I want a clean electric setup (without decasing) I'll try and find the proper gear this morning, if not I'll heyok technic (facepalm for not thinking about that before Have a great day. |
11-10-2012, 03:19 PM | #10 | |
Servo plugs without tools - Similar Threads | ||||
servo plugs???????? | captain.roche | Electronics | 11 | 11-06-2010 02:09 AM |
Are double male servo plugs available? | shelljeep | Electronics | 3 | 10-21-2010 08:38 PM |
