11-09-2012, 10:14 PM | #1 |
Newbie Join Date: Sep 2012 Location: San Antonio
| Several questions about wiring....
I am new to electric, new to crawlers but not new to RC. I will be wiring up my XR10 soon and have some questions, I have searched on the forum and google but I don't really know what words to use to find what I'm looking for. First what is the best place to buy wire, bullet connectors, plugs, shrink wrap etc? A place that carries it all! I know hobbypartz.com and hobbyking both have some of each but I like to try and get similar items all from one place. I know direct wiring is the best way to go but for the time being I want to be able to disconnect things until I get the crawler sorted out. I am assuming bullet connectors would be the best (3 or 4mm castle type stuff) but when wiring the motors what if I used solid wire and put spades on the ends connecting to the motor? Deans plugs...Well I have heard both good and bad about them. I ordered a set of 10 for now. Besides dean plugs, traxxas plugs and banana plugs what else is out there that is possibly better? Thanks for any help guys, override |
11-09-2012, 11:27 PM | #2 | |
| Re: Several questions about wiring.... Quote:
11-10-2012, 01:48 AM | #3 |
Newbie Join Date: Mar 2011 Location: bismarck
horizonhobbies.com is the biggiest destributer. deans makes great wire called "wet noodle", there is nothing wrong with using a deans inbetween your motor and esc. as far as shink and soldering stuff check out radio shack or horizon again. novak sells great shrink. no solid wire.. none and no spades.
11-10-2012, 06:44 AM | #4 |
Thanks trubble and tunnalram for the help One more question of the top of my head....I used to do a lot of custom mods and repairs on old gaming systems and silver bearing solder with a no clean liquid flux was the best I found for a clean connection between electrical joints. What is the choice of solder for you guys when wiring up all this stuff? |
11-10-2012, 06:55 AM | #5 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
I use a Harris cadmium free silver solder for all my connections with a no name no clean liquid flux. Ive been watching the build on RCNT. Your old man is a lucky guy!!
11-10-2012, 08:55 AM | #6 |
I've always used rosin core 60/40 solder for my rc electronics Sent from my iPad using Tapatalk |
11-10-2012, 08:59 AM | #7 | |
I expect, if everything goes smooth from here on out, that I should have the build done by the middle of next month before I go back to work again. Just in time for christmas Thanks for the info on the solder, sounds like all my old soldering gear should be just fine! I have a nice, but OLD, digital soldering station. Now if I can only find out what tips I need as my old chisel tip is just about dead. | |
11-10-2012, 09:38 AM | #8 |
Good advice so far. For bullet connectors I use 4mm gold plated from great planes they are available at tower, horizon hobby, ckrccrawlers etc. I've had good luck with harbor freight shrink tube and my favorite solder is deans.
11-10-2012, 03:37 PM | #9 |
| Re: Several questions about wiring.... Considering Im still using my 60W Hobicco soldering stick an old digital station should suit you just fine for your needs
11-10-2012, 05:06 PM | #10 |
Thanks a lot guys for the advice! I will get the build thread started over here when I get some time.
Several questions about wiring.... - Similar Threads | ||||
Castle wiring questions | zjguy721 | Electronics | 9 | 03-12-2011 11:18 PM |
New to Crawling, have some wiring questions | eddiepfund | Newbie General | 2 | 09-23-2010 01:22 AM |
LED wiring questions? | JavelinSST390 | Electronics | 3 | 11-11-2007 11:41 PM |
ESC / Servo / BEC Wiring Questions??? | RCholic | Electronics | 1 | 09-18-2007 06:11 AM |
winch wiring questions | mudrinner4ever | Electronics | 2 | 06-21-2006 10:29 AM |
