11-10-2012, 01:01 AM | #1 |
Newbie Join Date: Oct 2012 Location: Bloomington
| Motor noise help! Dont want to burn up motor
I have an EIGER pro and a Rockstar 35T with a BEC on my SCX10 and running a 2S 5000mah Lipo and a Spektrum DX3C, i have had no issues with the ESC the programing kind of sucks i would rather be able to plug it into the computer like the castles, Novak discontinued the Novalink deal. My problem is the motor just started to make a weird noise especially wide open, makes like a whining noise that's the best way i can describe it. but it seems to run OK and just gets warm. I know its not the ESC i know what that sounds like. I did not break it in, i just ran it fresh out of the box could that be why? I have only put about 2 hours on it so far. I also did not solder any caps on, its not glitching or anything so i did not see the need. Any info on how to fix this obnoxious noise would be much appreciated, and what would cause this? |
11-10-2012, 01:41 AM | #2 |
Newbie Join Date: Mar 2011 Location: bismarck
| Re: Motor noise help! Dont want to burn up motor
sounds like... <== lol either a bearing or poor gear mesh. try removing the pinion and running the motor. see if the noise goes away. if you still hear it a little bit of bearing oil goes a long way.
11-10-2012, 02:30 AM | #3 |
you read my mind i got it in my hand right now just got it out lol just doing a good ol' cleaning the muds starting to get to it. Thanks for the response! |
Motor noise help! Dont want to burn up motor - Similar Threads | ||||
Motor noise | Jagman | Newbie General | 4 | 07-16-2011 11:01 AM |
Motor burn after playing in water at 3s power. | Edison | Electronics | 3 | 05-07-2010 10:20 AM |
Motor Noise | Duramarks | Traxxas Crawlers | 2 | 01-19-2010 07:57 PM |
new build, new motor, new noise | Tatau | Newbie General | 5 | 05-20-2009 03:40 PM |
Motor noise in reverse | builder | Electronics | 2 | 02-28-2008 07:08 PM |
