servo jumping its a ae2 servo.. maybe the constant water has killed it.. was the first one i dipped. thought i would ask what else i should check.. thanks |
Re: servo jumping Quote:
or if you mean it 'twitches' and such, then yea I'd say the water got to it. But it is a cheap servo. you get what you pay for is how i look at it. I've got a bin full of cheap MG servo's that I rebuild. It'd be really nice when I can get a good servo so I can toss all my cheap shit. |
Re: servo jumping still workes but it twitches |
Re: servo jumping If all the wires are good, I'd say the board is toast, or just shorting out from a little moisture. I'd pull it apart, look inside, and check the board for moisture, but even if there's none.... I've had a few cheap servo's do the same thing with no moisture inside. I just use them for parts at that point and toss the board. Im fairly noob, maybe someone with more experience will chime in before you toss it. |
Re: servo jumping good idea.. save them for parts.. im going to take to apart and see |
