11-12-2012, 09:40 AM | #1 |
Quarry Creeper Join Date: Oct 2006 Location: Greenwood
| Problem
Got my wraith all finished up and took it out and the motor got really hot and would smoke. Then it would surge like a big blown drag car. I've tried two different esc's and motors. Running a 2cell, savox 500oz servo with spektrum electronics and a glitch buster. What could it be and how do I fix this? Thanks! |
11-12-2012, 10:18 AM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: in a van down by the river
Sounds like its in your tx/rx. If its still doing it with different motors/escs |
11-12-2012, 10:20 AM | #3 |
Moderator Join Date: Jan 2004 Location: chicago
| Re: Problem
i would eliminate the glitch buster doohickey and see what happens.
11-12-2012, 11:08 AM | #4 |
| Re: Problem
If I get rid of the glitch buster then the servo acts really spastic. Would it change anything if I got rid of the glitch buster and got a BEC?
11-12-2012, 12:45 PM | #5 |
| Re: Problem
What ESC's are you trying out? Did you calibrate the ESC's to the RX each time you swapped them? If the ESC's can do brushless & brushed, are they set to the correct motor type?? 500inoz servo WITHOUT a BEC, just asking for trouble. Glitch busters are to help a bit.....way outside of what you're seeing. Most of us run a CC 10A BEC. |
11-12-2012, 04:00 PM | #6 |
| Re: Problem
One esc is the axial AE2, and the other is from a HPI sprint 2 drift car rtr.
11-12-2012, 05:04 PM | #7 |
I don't think the glitch buster or a because would cause the motor to get hot and smoke. That's likely dorm drivetrain binding like your pinion mesh etc. Take the motor out and spin the tires, there should be hardly any resistance or u can push it on the floor. A bec is needed for that power hungry servo though. Sent from my SCH-R530U using Tapatalk 2 |
Problem - Similar Threads | ||||
Problem with Tekin RS system in my LCC, will a BEC fix my problem? | rcboy514 | Electronics | 3 | 01-12-2012 05:55 PM |
Tekin Problem or Radio Problem? | Harvo | Electronics | 8 | 07-30-2010 06:02 AM |
Little bit of a problem, Possibly big problem... | C_Money | Electronics | 11 | 03-08-2010 05:49 PM |
Charger problem or power problem? | Rockfrog | Electronics | 4 | 10-09-2009 01:10 PM |
* Problem * Clicking Problem on my 1/18th | clodman | General Crawlers | 6 | 04-08-2006 08:40 AM |
