Thread: Ae-2 ???
Old 11-13-2012, 04:03 AM   #1
Default Ae-2 ???
I know the LVC is factory set but is it possible to accidentally shut it off? When I first started using this rig it would "buck" when the battery was getting ready to puke. As of late I dont notice this "bucking" and the battery will drain completely. Ive got 3 new 2S batteries that I want to use but not if the LVC isnt working. Is there a way to "reset" to the on position or at least test to see if its on?
Phins Fan is offline   Reply With Quote
Old 11-13-2012, 05:58 AM   #2
Default Re: Ae-2 ???
do know about testing it. but heres how to program it.
if you dont have a castle link, scroll down to manual programing
Axial Racing - Axial AE-2 ESC Set-up and Programming
stanmondz is offline   Reply With Quote
Old 11-13-2012, 07:49 AM   #3
AddictedtoRC1's Avatar
You can try and test it by hooking up a battery that is below 6V. If LVC is on the ESC shouldn't arm.
AddictedtoRC1 is offline   Reply With Quote
Old 11-13-2012, 08:02 AM   #4
It's also possible that the battery you're using can't handle the amp draw and the LVC is kicking in under high load situations. For instance if you're running a 2s4000 20c the battery 'should' handle 80 amps continuous, but that's not always the case. Lately I've been buying 30-40c lipos just for a measure of safety. I also don't run my lipos down past 3.7v per cell. You can either program the ESC to a higher LVC level, get a battery checker like this one (run your truck for 10 minutes on a fully charged battery, check the levels and see what the cell voltage is at), or get a low voltage alarm like this one and use that. What are you running?
road_rascal is offline   Reply With Quote
