11-16-2012, 09:47 PM | #1 |
Newbie Join Date: Dec 2011 Location: surrey, BC, Canada
| micro lipo question
hey guys so i just got 4 hyperion CX G3 25C 240mah 2cell lipo and its the first "small" lipo ive ever gotten and i cant figure out wy it just has a charging wire and not a cell balance wire... and i have a few questions. 1. isnt a two or more cell lipo supposed to have a cell equalizer wire...? 2. can these lipos run dead or do i need some kind of voltage alarm? any help would be appreciated |
11-17-2012, 05:13 AM | #2 |
| Re: micro lipo question
1-Some small 2S LiPO's I've had used an internal balance board, thus no external balance wire. 2-Hopefully your ESC has a LVC which works off pack voltage, not the balance wire. If your ESC does NOT have an internal LVC, then yes, you can over-discharge your pack which is a bad thing. |
11-17-2012, 06:58 AM | #3 |
Pebble Pounder Join Date: Aug 2011 Location: San Antonio TX
what truck are you running them on? I have the 380mah lipos I use for my micro crawler. They stop right at the limit
11-17-2012, 10:38 AM | #4 | |
| Re: micro lipo question Quote:
Can't say yours will be like this, too. I really hate to say 'you won't know if it'll work until you try', because these are still LiPos, they'll still bite you if mis-handled. If you can work in a way to hook up an alarm, or set an LVC, that might be a good way to go. Otherwise, gonna hafta set a conservative timer (5-8 mins.) and check your voltage to see if you can push it a little longer. | |
micro lipo question - Similar Threads | ||||
micro lipo | smuggl1n | Electronics | 0 | 09-03-2012 05:57 PM |
micro lipo and charger | cammok5 | Electronics | 0 | 09-13-2010 07:35 PM |
Anyone Using the Micro-T LiPo | notez2beat | Losi Micro-Rock Crawler | 3 | 12-17-2009 11:39 AM |
Micro rock crawler lipo charge question | sirbikealot7 | Electronics | 0 | 12-14-2009 10:40 AM |
