11-19-2012, 08:34 AM | #1 |
Pebble Pounder Join Date: Dec 2010 Location: Veneta
| Spektrum DX3C Questions
I have a wraith and want to add lights, winch, and dig. I only have a 3 (with bind port) channel receiver. Can I run lights and winch off 1 receiver plug? What options do i have? Is there a another receiver avalable that will work with dx3c? Thanks again.
11-19-2012, 10:19 AM | #2 |
| Re: Spektrum DX3C Questions
That transmitter has three channels. You have to decide how you want to run with CH3. Because you want both dig and a winch you have to choose one or the other or put a toggle switch on your rig to send the CH3 signal to either your dig controller or winch controller. As for lighting, you can just plug it into the bind port or run a Y cable from any of the outputs of the receiver. Spektrum makes a few receivers that are compatible with your transmitter, but in the end, you will still only have a three channel transmitter. Was that of any help to you? |
11-19-2012, 11:40 AM | #3 | |
| Re: Spektrum DX3C Questions Quote:
11-19-2012, 02:32 PM | #4 | |
The input of the switch connects to your receiver and the outputs go to the two items you want to control (one at a time!). How does the toggle switch work? Flip it one way and CH3 runs the winch. Flip it the other way and it runs your dig. Last edited by heyok; 11-19-2012 at 02:53 PM. | |
Spektrum DX3C Questions - Similar Threads | ||||
spektrum dx3c... need help | lordjasper1988 | Electronics | 2 | 04-21-2012 06:18 PM |
spektrum dx3c | rmiranda134 | Electronics | 2 | 03-17-2012 01:45 PM |
Spektrum dx3c | EL VASCO | Electronics | 6 | 11-19-2011 10:58 AM |
Spektrum Dx3c | MXRac3r545 | Electronics | 3 | 09-26-2011 10:28 AM |
