11-22-2012, 12:05 AM | #1 |
Rock Crawler Join Date: Mar 2011 Location: hampton
| motor stalling. not clod stall
its a 65t integy in my 6x6 i just built, (but had same problem with the ax10 that was used for the 6x6 build)with a sidewinder v1 esc. iv tried a different known good esc, 2 other known good motors, different tx/rx. all of which had the same issue in both trucks.my servo is powered strait off the 2s main pack. geared 14/87. mesh is right, and no drivetrain bind. unless something is binding under load. everything spins free on the bench. no excessive slop in the tranny or axles to cause parts to move around under load. batteries are 2s 4000mah 20C, and i tried a 1300 2s 40c. both packs are good and charged. i recalibrated the esc/radio and checked everything else in castle link. same settings i run on other castle esc's. the esc isn't going into protection, or getting warm. the motor will get hot fast if i stay on the throttle what am i missing |
11-22-2012, 06:34 AM | #2 |
When was the last time the motor was rebuilt?
11-22-2012, 07:40 AM | #3 |
| Re: motor stalling. not clod stall
when i started acting up in the ax10. maybe 2 packs on it since then. fresh cut,new brushes and cleaned and oiled baring |
11-22-2012, 07:57 AM | #4 |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
| Re: motor stalling. not clod stall |
11-22-2012, 08:33 AM | #5 | |
| Re: motor stalling. not clod stall Quote:
If the other motors work on the original ESC and the 65T has issues on any ESC, then yes, since it's been serviced I would agree it's a stalled/shorted armature. I've had it where the rig sits there even with throttle, but give it a nudge it works fine until you stop it again. The only fix is a new armature or a new motor....unless you can wind your own arms. | |
11-22-2012, 08:49 AM | #6 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
Would it act like that if the esc was in brushless mod?
11-22-2012, 10:32 AM | #7 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
Check brush movement in the brush hood also check the brush springs I had the same thing happen after a rebuild cleaned the brush hoods an new spring prob gone hope this helps
11-22-2012, 12:03 PM | #8 |
11-22-2012, 04:52 PM | #9 | |
motor stalling. not clod stall - Similar Threads | ||||
Motor stalling | Jus | Electronics | 1 | 10-21-2012 04:28 PM |
front motor has clod stall | asw27x | Electronics | 6 | 05-11-2011 05:39 PM |
Motor stalling out? | jkwrangler08 | Losi Mini-Rock Crawler | 10 | 09-14-2009 03:09 PM |
Motor stalling out? | customxprone1 | Electronics | 4 | 04-02-2006 11:49 PM |
Axle Stall (clod stall) | TheRangerman0 | General Crawlers | 2 | 03-31-2006 11:23 PM |
