11-28-2012, 06:00 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: Harrisburg on the way to Wingate
| Steering effecting throttle? Help
Just finished building my XR10 last night and have it all wired up. Here is the parts list. Novak M2 Dig Dual Rock Star 45T CC BEC 10A Hitec HS7955TG Spectrum SR300 3 Channel Venom 3S1P 20C 1300mAh Rx is set up with dig in aux, servo in steering, ESC in throttle and BEC in bind. Cut the red power wires on both the throttle and dig as directed for 3S battery use. Followed directions for calibrating the ESC to my DX3S and thought it was all good. I put the truck on the floor and tried it out, goes forward and back with no problem under throttle. When stopped for about 5 seconds it will jump into reverse until forward throttle is applied. Second problem is the when steering it engages the throttle and the dig function jumps back and forth. Steer left and it crawls forward, steer right and it goes in reverse. ANY IDEAS???? |
11-28-2012, 06:42 AM | #2 |
Quarry Creeper Join Date: Aug 2012 Location: Melbourne
We're your trims set to neutral when calibrating the rx and esc? I found the M2 instructions as clear as mud when I had mine installed. Took a while to get it all calibrated and setup correct (mt4 rx). |
11-28-2012, 07:02 AM | #3 | |
| Re: Steering effecting throttle? Help Quote:
Also, how are the batteries in the TX? Even new ones can be bad. | |
11-28-2012, 07:30 AM | #4 |
| Re: Steering effecting throttle? Help |
11-28-2012, 07:48 AM | #5 |
Followed the instructions to the T. Calibration was pretty simple. Directions said to cut both red wires on throttle and dig leads if running 3S on a BEC which I am. Im pretty sure the trims were at zero, I tried adjusting multiple settings with no change. Two separate batteries were tried, both brand new and fresh charged. Olle P, the BEC in the bind port provides power to all the functions such as Dig and steering servo. |
11-28-2012, 03:21 PM | #6 |
11-29-2012, 05:19 AM | #7 |
| Re: Steering effecting throttle? Help No just the ESC and dig function (included internally on the BEC) Found the problem, BAD Rx!!! Brand new out of the box. Swapped out for the second new one that I had installed on my CR-01 and it worked correctly. Now I just need to figure out the throttle curve settings so its not extremely jumpy. Any suggestions on this? |
11-29-2012, 09:43 AM | #8 | |
As to setting throttle curves in the M2, I never did find a good setting in the ESC itself. Others have used expo in the TX (if you have it). For me, running 3S & decent 35T motors, the M2 was poor in initial throttle. It didn't really work well, then sorta "took off". Once moving, I could slow the rig down and crawl, but never had good luck from stopped. This is part of why I no longer own an M2. | |
Steering effecting throttle? Help - Similar Threads | ||||
ax10 that has steering but no throttle | asw27x | Axial AX-10 Scorpion | 11 | 07-30-2010 04:19 PM |
Steering but no throttle | 2JSC | Electronics | 16 | 05-09-2010 12:18 AM |
Steering induced throttle- | mckenzies | Electronics | 6 | 05-06-2010 09:41 AM |
Steering lock w/ throttle | Just Zach | Electronics | 4 | 11-11-2007 10:42 AM |
