11-29-2012, 09:36 PM | #1 |
Quarry Creeper Join Date: Apr 2012 Location: Marietta
| novak ballistic 13.5 ?
I just put a Novak 13.5 ballistic crawler motor in my wraith and it seems fast in reverse! Is this a timing issue? I think I remember reading somewhere that the wraith is a reverse rotation drivetrain. So if I retard the timing will that make it run correctly?
11-30-2012, 04:11 PM | #2 |
Rock Stacker Join Date: Nov 2011 Location: Huntsville, Al
| Re: novak ballistic 13.5 ?
Yes, the drivetrain on the Wraith is reverse rotation. I do believe all you have to do is retard the timing down to 0 . I had to do the same thing on mine when I put a VP DIG in my SCX-10. Also don't run it with the timing like that for long, I remember on mine the motor heated up fairly quickly. Ben |
12-01-2012, 05:29 AM | #3 |
So 0 degrees would be with the three screws lined up even with the solder tabs and slightly retarded would be past that!
12-01-2012, 05:46 AM | #4 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
I just played around with mine. Not sure where 0* would be, you tried it? Loosen the 3 srews some, then knock on one of the screws while ya have the allen key on it. Should turn easy then. For now mines at the 15* mark ,esc set at rev and rev at 75%. Forward is faster for me, ill just have to check temps over time. Last edited by Cableman; 12-01-2012 at 05:53 AM. |
