11-09-2015, 12:28 AM | #141 |
Pebble Pounder Join Date: Jan 2004 Location: Strawberry
| Re: Flysky FS-iT4
Ok here is my problem, If you notice the throttle you'll see that the brake/reverse is on. I have went through the radio looking at everything that has to do with brake and throttle and cant find any way to set it to off or center?? If i'm missing something please fill me in... the radio came with the 1.01 US and I updated to 1.02 US when I received it.. Please help... |
11-09-2015, 04:27 AM | #142 |
Rock Stacker Join Date: Jan 2015 Location: Kansas
| Re: Flysky FS-iT4
Check your throttle sub trim Sent from my SM-G900V using Tapatalk |
11-09-2015, 07:59 AM | #143 |
| Re: Flysky FS-iT4 |
11-09-2015, 12:46 PM | #144 |
| Re: Flysky FS-iT4
Did you try factory resetting the radio Sent from my SM-G900V using Tapatalk |
11-09-2015, 03:23 PM | #145 |
| Re: Flysky FS-iT4 Yes, I have factory reset it a couple times, it just resets any custom stuff you have setup back to the factory settings. I thought it would reset back to the original firmware but it doesn't..
11-12-2015, 06:58 AM | #146 |
| Re: Flysky FS-iT4
Did you try the steering exponential Sent from my SM-G900V using Tapatalk |
11-14-2015, 01:41 AM | #147 |
| Re: Flysky FS-iT4 Well i got it figured out, apparently i was doing the wrong reset. I didn't know about the mode where you hold full brake and hold trim 4 button full back and turn radio on. it takes you to some type of test menu, I did the factory reset through that menu and everything is correct and working... |
04-08-2016, 09:17 AM | #148 |
Newbie Join Date: Mar 2016 Location: Hochatown Oklahoma
| Re: Flysky FS-iT4
I have had nothing but bad luck with the fs it4 . I watched video after video , read blogs , posts and threads , before I ever turned it on . Built my trail finder2 with 2 speed transmission. Well atempimting to bind it , I knew nothing about having to adjust end points before binding. I lost a 54.00 servo for my transmission. Now ,with the cost of the it4 and a hitek wp servo I'm not too happy. But wait, when trying to bind the menu hasn't got the afhds2 in it. The motor runs forward or backward when it wants to , pull the trigger and maybe it will move or it won't. I bought it new I still have the box and everything. And then I have to bind it every time I unplug the rx battery. Its pretty to look at and push buttons on the screen, but my 54.00 servo is pretty to look at too, but thats all its good for to me. It actually makes me mad to think about. Please, can someone help me here? Sent from my GT-P3113 using Tapatalk |
04-08-2016, 09:59 PM | #149 | |
Pebble Pounder Join Date: Aug 2013 Location: San Jose
| Re: Flysky FS-iT4 Quote:
After you make sure all of those are set to Zero and Normal, then go ahead and bind it. After binding and you try to throttle FWD and your wheels spin to backwards, then you change CH 2 to Reverse. When you turn steering to Right and wheel points Left, then set CH 1 to Reverse. On cheapie FREE remotes included in a lot of RTRs and there are NO end points, usually the soft plastic steering links and/or servo savers are what prevents the damage to servos. I'm sure on your TF2 KIT, the link you used for the 2sp transmission servo is a hard link (without any give) and probably not a servo-saver servo arm either. In which case, the End points on CH 3 need to be set for the shifting action of your transmission servo...and I'm pretty sure it will be a very small throw. If that CH 3 is at 100%, then you will be destroying a lot of servos. Sent from my ONE A2005 using Tapatalk | |
02-06-2017, 02:47 PM | #150 |
Rock Crawler Join Date: Jun 2013 Location: Portugal
| Re: Flysky FS-iT4
Hi guys, I have the Carson REFLEX WHEEL Ultimate touch that is a rebranded Flysky IT4. My problem was that I've bought a FS-IA4B receiver for the IT4/IT4S and every spec looked similar. But it fails to bind. Tried to update the firmware. unchecked the AFHDS2 box. the radio is this: CARSON*::*Produkte*::*Fernsteueranlagen*::*Drehkno pfsender*::*Produkt Details and the receiver: CARSON*::*Produkte*::*Fernsteueranlagen*::*Empfäng er*::*Produkt Details Any ideas? |
08-30-2017, 02:46 PM | #151 |
Newbie Join Date: Aug 2017 Location: Victoria
| Re: Flysky FS-iT4
HI Guys!! I've just purchased the FS-IT4S and I'm hoping somebody can help me set my dig up. I seem to be able to switch from front to rear (through either the 3rd or 4th channel) but it wont allow me to apply both motors at the same time. There are so many mix settings and extra switches on this, I think I'm in a little over my head on this one.. Thanks in advance
07-03-2019, 05:32 AM | #152 |
Newbie Join Date: May 2019 Location: Bruton
| Re: Flysky FS-iT4
A hack just to change fonts and colours to your liking looks like it would be more than sufficient. Only thing lacking is aesthetic appeal of u.i. Sent from my S60 using Tapatalk |
05-23-2020, 10:40 PM | #153 |
Newbie Join Date: Feb 2015 Location: milford
| Re: Flysky FS-iT4
Anyone have trouble updating firmware. The firmware app does not seen to recognize my controller. My computer recognizes it but when I go to controller the update it just sits at the "remove battery to restart" screen and no change to firmware screen it remains blank and update button does nothing. Any clues guys? FYI I'm on 1.07-cn hardware 2.1 |
01-16-2022, 07:31 PM | #154 |
Pebble Pounder Join Date: Aug 2008 Location: Sunshine Coast Queensland Australia
| Re: Flysky FS-iT4
i have a iT4 I was wondering what other people are using as a second battery as i can not find anywhere that i can get a B1200 does the one out of a GT3C fit BA800 |
01-16-2022, 07:34 PM | #155 |
| Re: Flysky FS-iT4
maybe this i have found that this is replace Need battery for FlySky FS-GT3C https://usa.banggood.com/Flysky-BA17...ientCountry=AU |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/415424-flysky-fs-it4.html | ||||
new flysky rc radio - All things electric... - Tamiyaclub.com Forums | This thread | Refback | 02-17-2013 09:16 AM |
Flysky FS-iT4 - Similar Threads | ||||
Flysky fs-t6? | Tgreer | Electronics | 12 | 09-16-2013 04:13 AM |
FlySky troubleshooting | WAM | Electronics | 10 | 06-11-2012 07:33 AM |
Help me get my flysky working PLEASE! | WestTxRc | Electronics | 14 | 11-18-2011 10:28 AM |
FlySky GT-2 TX | WAM | Electronics | 6 | 09-19-2011 06:55 PM |
flysky gt3b | EMUTT | Electronics | 14 | 09-07-2011 11:13 AM |
