Naked FXR's So I hear all the buzz in the pro comp scene about decasing the FXR shortening wires, eliminating the on/off and removing posts. I gave it a try, let me know what you think... Attachment 216961 |
Re: Naked FXR's WOW, thats tiny. Make sure no water gets near it!! |
Going to finish it up with some liquid tape. |
Re: Naked FXR's Does it cover the buttons? |
Re: Naked FXR's When you get it done post up your temps please"thumbsup" |
Re: Naked FXR's Quote:
Thanks for the great questions and feed back. When the next one is done I'll post up. need to go to the LHS to get one more. |
Re: Naked FXR's Conformal Coating "thumbsup" |
Had zero issues with it in water..... Also that rubber junk for tool handles is awesome too. They are looking for temps of the esc while it runs since fxr tends to run on high side due to no cooling fins. "thumbsup" |
The FXR used the power connectors as a sort of make shift heat sink. I think as long as you use an external BEC, and treat them as a comp rig would get used ( run a pack and allow some cool off time) they have proven reliable. I am not sure I would want to run pack after pack for hours on end without any heat sink and expect a long life. |
Re: Naked FXR's The FXR's decased will last for sometime, however having ran them for about 3 seasoned uncased and without the soldering tabs I've found out they do have a shelf life, and that shelf life has always seemed to be different. Conformal coating is about the only coating I would use, it produces the less heat build up out of any other option which is key in making sure these last the longest possible |
You must live by me. I'm in a corner lot between Hitler and Charles Manson |
Thanks for the input, I need it. I do have corrosion X but never tried it on electronics. Learn some thing new every day. I will let you know about the temps after I run it a few times. |
So here is kind of what the final set looks like. Attachment 217381 |
Re: Naked FXR's Not bad but if you need to get them smaller you can. If you stick them back to back and use 18awg wire then shrink wrap them you can get them much smaller and sealed up better i think. I run them in my super and my 2.2 with the same setup shown below. There are also two BEC's under the fxr's. http://i189.photobucket.com/albums/z...n/DSCF0425.jpg http://i189.photobucket.com/albums/z...n/DSCF0421.jpg |
props on getting that all in there though. looks awesome!!"thumbsup" compact... I LIKE IT |
1 Attachment(s) |
