12-01-2012, 08:02 AM | #1 |
Quarry Creeper Join Date: Jul 2007 Location: Hangtown Ca.
| how many servos can one castle bec run?
Hey there, I have a scx10 and was wondering if anyone knows if i can run both my steering servo and my servo winch off of the same castle 10 amp bec. I wire my bec into the servo leads so could i just solder the second servo in line with the steering? would it be to much draw for one bec or because the winch is so seldomly used could I pull it off? Any facts or assistance would be and will be greatly appreciated! |
12-01-2012, 09:15 AM | #2 |
| Re: how many servos can one castle bec run?
I run a MMP one cell in my 1.9, so I use a single Castle 10A set to 8.4V to power everything. Rx, 7954 and 3racing winch with power/control wires bridged. It's never had a problem and I could probably add a few LEDs.
12-01-2012, 09:19 AM | #3 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
With your set up you should be ok. I would not run more than 2 but since you probably will not load both the servo and the winch at the same time you should be ok .
12-01-2012, 02:16 PM | #4 |
what would happen if i were to run both at the same time?
12-01-2012, 02:38 PM | #5 |
It really should be OK. I run 2 hitec 7950's on my Wraith (front and rear steering )and don't have any issues unless I really load both servos hard at the same time. It will bug out a little, but recovers fine. Unless your really running a power hungry servo that is bound up at the same time your running your winch hard I would not see any issues. If you are worried about it you could run the BEC pro. I run 2 7950's and a 7980 off of it on my super without any issues. It is larger, but IMO well worth it if you plan on adding anything else in the future.
12-01-2012, 02:58 PM | #6 |
Here is one CC BEC powering 10 servos that are lifting 100lbs: |
12-01-2012, 03:04 PM | #7 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Interesting question to say the least.... Make me wonder who's running multi off of one bec. I have 3 one to each steering and one to winch. Figured $20 each is quite cheap really. Also if one fails all rest will still work. All on c3 rig..... Kinda lol
12-01-2012, 07:13 PM | #8 |
thanks folks! From the looks of the video....................I'm GOOD!!
12-01-2012, 09:29 PM | #9 |
Rock Crawler Join Date: May 2012 Location: Australia
On my scaler I use 1 bec- to run my steering, dig and winch servos. Servos are all hitec 7955. I never really used all at once. Used steering and dig or steering and winch. I have had never issues On my super I did use 1 bec- to power 2 hitec 7980, I've had no issues at all with this set up. |
12-01-2012, 09:34 PM | #10 |
Your two biggest limits will be the reaction speed and servo efficiency. Cheaper servos tend to be inefficiency and amp hungry, Savox is a good example. If you "twitch" a servo it draws a lot too. On a name brand servo like futaba about 800 ounce/ inches of power seems to be a good margin for servo power in a crawler with the slower speed versions.
12-01-2012, 09:48 PM | #11 |
Newbie Join Date: Nov 2012 Location: Ontario
I just wired up my CC bec to 2 Savox 1256 to control my 4ws. the CC bec says it can put out 10amps @ less than 12V input. RATED: Power HD 1501/1217HV, Savox 1256/1267HV, and more... - Radios & Servos @ URC Forums and from this link I figure the 1256's can only draw 6 combined. I soldered the connections as castles instructions say their connectors are only good for 5amps. so far so good but I have only run it around in the house! heading outside tomorrow for some test runs! |
12-01-2012, 10:00 PM | #12 |
Sweet setup!
12-02-2012, 11:16 AM | #13 |
Rock Stacker Join Date: Mar 2012 Location: longview
Im running a savox for steering and a hitech for winch with no problem. I also have a pro standing by |
how many servos can one castle bec run? - Similar Threads | ||||
Does anyone run BEC other than Castle? | mmatthews | Electronics | 14 | 11-27-2012 09:13 AM |
how do I wire/solder a Castle 10A BEC to an AE-2 esc, to run 3S LiPo? | ussprinceton2004 | Electronics | 9 | 02-09-2012 02:18 AM |
Castle BEC & Castle Link - not finding BEC | Locked Up | Electronics | 22 | 12-20-2007 03:37 PM |
