12-02-2012, 10:15 PM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: Rocky Hill
| BEC as a resistor for an ESC
OK someone in the wanted section on here is buying a BEC to use before his esc so he can drop the volts of a 3s or 4s battery down to 2s. Am I crazy or does this seem like a bad idea to anyone else? I guess it could work but then you still need some sort of low voltage setup as well. Has anyone done this before? Has anyone done this before successfully? It just doesn't seem to make sense especially in this time of $10 and cheaper lipos?
12-02-2012, 10:18 PM | #2 |
RCC Addict Join Date: Sep 2006 Location: Depew
| Re: BEC as a resistor for an ESC
What's the point of running anything bigger then 2S if you don't want to use the volts??
12-02-2012, 10:48 PM | #3 |
I run a bec to a small esc for winch duties. Actually split at 7.5v to steer servo and winch esc. As a main motor esc, not sure it's worth it. The motor amperage would be limited by the bec. |
12-02-2012, 10:56 PM | #4 |
Pebble Pounder Join Date: Oct 2012 Location: Graham WA
Heh, I was just reading that thread, then I seen this. I dont see the point in it either, an ESC that cant handle 3s, shouldnt be ran with a 3s. limiting the votage sounds like a wasted battery. I think he is either confused, or by chance we are mis understanding the intentions. A smaller battery is cheaper than a BEC. |
12-02-2012, 10:57 PM | #5 |
| Re: BEC as a resistor for an ESC I didn't think of winch control. This makes sense. I only ASSUMED he was going to use it on his main motor. And we know what happens when we assume...
12-02-2012, 10:58 PM | #6 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
| Re: BEC as a resistor for an ESC |
12-03-2012, 06:03 AM | #7 |
BEC to FEED a ESC??!! Good way to kill a BEC IF it's to be used for the drive motor. For the money of a BEC, just get 2S LiPO's. BEC to feed a winch controller (not counting a ESC as a winch controller), servo, etc. is OK and done all the time. |
BEC as a resistor for an ESC - Similar Threads | ||||
LED voltage/resistor calculation | ik632 | Electronics | 7 | 01-30-2012 03:48 PM |
resistor question | BigSki | Electronics | 2 | 05-08-2011 09:47 PM |
Another resistor ??? | 86 Iroc | Electronics | 3 | 12-22-2009 07:27 AM |
what resistor to put on lathe motor? | jj650 | Electronics | 9 | 04-02-2006 12:20 AM |
Receiver BEC (vs ESC BEC) | sim | Electronics | 7 | 10-13-2005 07:54 PM |
