12-15-2012, 07:33 PM | #1 |
Pebble Pounder Join Date: Oct 2010 Location: Boulder, CO
| Need help finding long screw for servo horn
I have a Hitech HS-645 MG with a War Pig winch spool. Does anyone know what type of long screw I need to hold it on and where I can get it? It needs to be about 16mm long.
12-15-2012, 07:42 PM | #2 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: Need help finding long screw for servo horn
Hitec sells a pack of screws but none are that long. ALSO, hitec uses a funky threading so it might be a tough road. Maybe get ahold of the spool maker to see what they use. Edit: 2.6mm x what ever length you need. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTW34 longest is 12mm in this pack. Last edited by The Violator; 12-15-2012 at 07:46 PM. |
12-15-2012, 07:56 PM | #3 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
Drill out and tap the servo to 3mm, that is my recommendation to everyone. The servo gear/spline is aluminum so it's easy to do. Makes it easy to find the screw, replace one and torque the thing down.
12-15-2012, 08:37 PM | #4 |
Thanks for the help, and the quick replies! Sent from my ADR6400L using Tapatalk 2 |
12-15-2012, 08:55 PM | #5 |
| Re: Need help finding long screw for servo horn I thought it was steel. Maybe just on the stronger servos, or are all the hitecs AL.
12-15-2012, 09:01 PM | #6 |
| Re: Need help finding long screw for servo horn |
12-16-2012, 06:41 AM | #8 |
Newbie Join Date: Feb 2012 Location: ca
screw size for Hitec servos are m2.6. m2.5 screws will not stay tight and have fallen out for me. a 10 or 12 mm long screw should be long enough.try pressing the pulley on a little further, the splines on those pulley are small and require more force to seat them properly. good luck.
06-24-2013, 10:07 AM | #9 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| Re: Need help finding long screw for servo horn i know i'm pulling up an old thread. i have a servo winch that is going to have a custom spool that is a fair bit wider than any 2.6mm screw available. the servo i'm using is a 7955tg. seeing this thread has me concerned about drilling/tapping it to a 3mm, which was my plan. anyone done that before? advice?
06-24-2013, 10:09 AM | #10 |
worst case i have a 645 also. not ideal but would i simply be able to swap output gears between the two give drilling/tapping the 645 gear would be easy?
Need help finding long screw for servo horn - Similar Threads | ||||
Long NON clamping servo horn | Erik D_lux | Electronics | 34 | 11-01-2012 12:14 PM |
HighER Leverage Steering without the Long Horn | Vertigo | Axial XR10 | 0 | 04-12-2012 11:11 PM |
horn screw for savox servi | Bob Wieking | Electronics | 2 | 12-09-2011 06:20 PM |
Integy long servo arm/horn....caution | Charlie-III | General Crawlers | 2 | 06-12-2011 04:39 PM |
Need help finding a TLT screw | CJBrad | Tamiya TLT Crawlers | 6 | 10-15-2008 03:11 PM |
