Thread: Forwards is backwards. I think?
Old 12-18-2012, 01:31 AM   #1
Default Forwards is backwards. I think?
Hi there, I think my Novak terra claw seems to be running backwards. That is its faster backwards than forwards.
Can anyone help me out? Im new and dont know what im doing.
Thanks
totalamature is offline   Reply With Quote
Old 12-18-2012, 02:28 AM   #2
Default Re: Forwards is backwards. I think?
Most probably it's your ESC running in reversed mode. Most ESCs have reduced reverse speed by default.
The solution is to reverse the output on your transmitter and switch place on the motor cables.
After that you might also see if the ESC can be reprogrammed to provide 100% speed in reverse too.
Olle P is offline   Reply With Quote
Old 12-18-2012, 06:29 AM   #3
Originally Posted by Olle P View Post
Most probably it's your ESC running in reversed mode. Most ESC's have reduced reverse speed by default.
+1....These are the first things I would check.
Depending on the rig, the motor may need to have "reverse rotation" (easy to fix) but also has some timing in it which could also lead to a difference in speed between forward & reverse.
Try out Olle's suggestions, if it's still an issue, you will need to check the timing on the motor.
Charlie-III is offline   Reply With Quote
Old 12-18-2012, 03:19 PM   #4
WAM
I think the first thing you should do is check to see if your esc has status lights telling you what's happening. On mine when I trigger forward I get a green light, reverse gives a red light, neutral is amber.
If I get a red light when going forward, I know I've got it wired and/or programmed backwards. Even tho it's moving in the right direction.
WAM is offline   Reply With Quote
Old 12-18-2012, 03:36 PM   #5
The terra claws are sealed can motors so the problem would have to be in the esc/tx settings.
SINister is offline   Reply With Quote
Old 12-28-2012, 06:48 PM   #6
I had the same issue when building my XR10 with a Novak M2. Ended up he only way to fix it was to swap the motor leads down at the motors. Ended up + to - and - to + but it works flawlessly now.
Got_Demo is offline   Reply With Quote
Forwards is backwards. I think? - Similar Threads
motors at different speeds forwards and backwards wade toombs Axial XR10 26 01-09-2012 12:27 PM
Backwards or not.............. BC_4RUNNER Axial XR10 17 11-13-2010 07:22 PM
sidewinder stopped working forwards jordi555 Electronics 5 12-26-2009 04:34 PM
SWX - Backwards/Forwards?? Confused TheOtherSide Axial AX-10 Scorpion 14 11-02-2009 12:21 PM
My rear axle wont go forwards.. Need Help! diablo0072k General Crawlers 1 03-22-2006 07:17 PM
