12-18-2012, 05:52 AM | #1 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
| 1S x 2 = a 2S battery?
Curious about a couple battery setups for an AX10 build. Like the old NI packs we used to put onto the front axles (1/2 pack each side of the axle with a connector giving you "1" pack) could you theoretically take 2 1S packs and run a parallel connector and give yourself a 2S pack out of a lipo or no? Obviously this would double the mah rating but what about the burst rate? would 2 30C 1S packs give you a 60C burst rate or no?
12-18-2012, 06:22 AM | #2 |
Pebble Pounder Join Date: Nov 2012 Location: Australia
You'll need to run in series not parallel.
12-18-2012, 08:10 AM | #3 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
| Re: 1S x 2 = a 2S battery?
Cilyx is correct, running two 1 cell lipos in series will equal a 2s battery. Running two 1 cell lipos in parallel will add the (2) mAh together, increasing run time NOT voltage.
1S x 2 = a 2S battery? - Similar Threads | ||||
UK Version please - LOSB0862 Battery Charger & Battery. | newth | Losi Micro-Rock Crawler | 7 | 05-26-2010 01:38 AM |
Finding bad battery cells in a battery pack. | ToTheMAXXcrawler | Electronics | 9 | 02-04-2010 10:14 AM |
*No Battery* message w/battery connected to charger? | pantablo | Electronics | 5 | 03-19-2008 11:06 AM |
