12-18-2012, 11:00 PM | #1 |
Newbie Join Date: Nov 2012 Location: Canungra, Down Under
| Goat 3s solved
Have solved my goat 3s glitching/cutting out problem.. Just wound the wire from the bec to the reciever through a ferris ring & plugged in as normal. this has fixed both me & my son's Goat 3s esc's . Running them on 2s & 3s 5000mah . Have been testing them for 2 days over 3hrs of run time each without a single problem. Before I did this we had glitching/cutting out every battery pack. Trying to attach some pics of what a ferris ring looks like, should be up soon. Hope this helps anyone with same problems.. |
12-18-2012, 11:02 PM | #2 |
RCC Addict Join Date: Dec 2011 Location: Australia Queensland!
| Re: Goat 3s solved
I've heard of this in the losi section, someone put a ferris on there and it solved their glitching issue's must really work then.
12-18-2012, 11:08 PM | #3 |
| Re: Goat 3s solved
I thought It would be another wast of time , But It really has worked. I now wonder why novak don't supply one with the combo. |
12-19-2012, 05:40 AM | #4 |
| Re: Goat 3s solved
I believe you mean a "Ferrite" ring. Now, tell us a bit more about it since there are different types & shapes and just "any old ferrite" may not get the same results. Yes, ferrites can clamp down unwanted noise in a signal wire, but I would try to do it without a ferrite. Glad it helped out though. |
12-19-2012, 03:11 PM | #5 |
| Re: Goat 3s solved
Yep, Wasn,t sure if they were called a ferris or ferite ring. Thankyou ,Now I no for sure.. I have tried to attach a pic but I need to join up first. It's a ferrite ring off an Align 500 helli esc. Ring is 1/2 inch diametre & 3/16 width. Green in colour looks like a plastic coating over the metal. -I,m using a spectrum dx3c. -3s 5000mah & 2s 5000mah 40-50c batteries. -Novak Goat3s 18.5 ballistic motor. -Proline chisel tyers. |
Goat 3s solved - Similar Threads | ||||
Still no Steering. SOLVED | JKMotorsports | Electronics | 32 | 02-16-2012 04:04 PM |
fxr problem?---*SOLVED*--- | Mr. crawl | Electronics | 13 | 07-26-2011 10:15 AM |
locker issues solved | 1\4elliptic toy | Venom Creeper | 33 | 01-30-2011 03:57 AM |
driveshaft problem solved | crawler-kid | Venom Creeper | 4 | 12-15-2009 04:18 PM |
