Thread: Axial esc problems
Old 12-26-2012, 08:44 AM   #1
Default Axial esc problems
I'm having trouble with the stock esc in my scx10. It is only sending short bursts to motor even if I hold it full throttle. I tried to reprogram it but it still does it. Any help would be appreciated
Bermbuster210 is offline   Reply With Quote
Old 12-26-2012, 10:05 AM   #2
Default Re: Axial esc problems
How old is the motor? Maybe it needs a service?
What battery (chemistry, cell count, mah, "C" rating if LiPO)?
Did this work fine before but now has an issue?
Charlie-III is offline   Reply With Quote
Old 12-29-2012, 10:14 AM   #3
It was still the stock one, had it about a year and a half. I have been running 7.2 volt 6cell 4500 mah battery packs through it. It was working fine when I last ran it bout two weeks ago.
Old 12-29-2012, 10:17 AM   #4
thats pretty old for a stock motor, the brushes might be shot
crawlhog is offline   Reply With Quote
Old 12-29-2012, 10:30 AM   #5
I joined the Band!
also i had problems with my 7.2v 6 cell.. i could drive it slow and get a burst of speed.. but once i punched it the truck jerked and wouldnt go..
went lipo and never looked back (this cheap guy was convinced lipo or nothing!!!!)
RootBreaker is offline   Reply With Quote
Old 12-29-2012, 04:55 PM   #6
I put in a traxxas water proof esc last night and it solved the problem. But I was hoping to be able to run the stock esc cause I know it's lipo compatible.
Old 12-29-2012, 06:24 PM   #7
I joined the Band!
well q for ya.. is it under warranty? was this a xmas time deal.. or have you had it for a long time?
Old 12-29-2012, 09:00 PM   #8
I've had it for some time now.
Old 12-30-2012, 02:34 PM   #9
guess it's a little late, but what battery connector are you running. If still the original tamiya style, I've had the same issue. Just makes a poor connection for some reason. Worth a look, maybe you can still use it after all.
94smasher is offline   Reply With Quote
Old 12-30-2012, 10:27 PM   #10
I was using the stock tamiya going through an adapter to traxxas style plug on the battery I'll look into it a bit more. Thanks for the help
Old 12-30-2012, 10:34 PM   #11
If thats a Xl5 Traxxas Esc than it is Lipo safe as well. Just run you a bec and you can run 3s all day.
Big Worm is offline   Reply With Quote
Old 12-31-2012, 12:00 AM   #12
Is the Axial esc set for Auto-LiPo (default setting)?
A fully charged NiMh battery can charge to 9+ volts so Auto-LiPo may see the NiMh battery as a 3 Cell LiPo, when you pull the throttle the NiMh battery will drop below 9 volts quickly so the ESC may be hitting LVC.
Turn Auto-LiPo off and try again or move up to LiPo's, you will never look back! The only thing you will wonder is why you stuck with NiMh batteries for so long.
SuperRoo is offline   Reply With Quote
Old 01-01-2013, 02:10 PM   #13
How do I go about changing the default settings on it?
Axial esc problems - Similar Threads
ESC problems.. xjcralwer7 Electronics 43 06-22-2012 07:16 PM
possible esc problems? j_the_pirate Electronics 5 05-16-2012 04:55 PM
Problems with Axial AE-2 esc nathan000 Axial Wraith 0 03-07-2012 04:40 PM
Axial AE-1 ESC Problems FireWire79 Axial AX-10 Scorpion 6 09-13-2010 07:50 PM
HELP ME axial esc problems!! Streamcrawler Electronics 3 05-03-2010 06:14 PM
