12-26-2012, 03:28 PM | #1 |
Rock Stacker Join Date: Apr 2011 Location: bergan
| Holmes Hobby br-xl won't go in reverse
I recieved a br-xl esc for Christmas and when i put it in my truck and turned it on, I found that the motor went foward but did not go in reverse. I tried calibrating it several times and still does the same thing. When I calibrate it I hold full throttle,and plug the battery in. The esc beeps then flashed red, but when I put the throttle in full reverse, the esc beeps with a red and green light. This seem to be different then what the direction say. Do you guys know what the problem might be? The transmitter is a traxxas tq 2.4ghz and the motor is a holmes hobby torque master 35t handwound if this is info. needed. Thanks! |
12-26-2012, 03:39 PM | #2 |
| Re: Holmes Hobby br-xl won't go in reverse
Congrats on a great ESC. Based on this..... Castle Creations | FAQ: 1/10th Scale Products , your specific issue does not appear. I would recalibrate, but: -Make sure throttle trims (and subtrims) are set to "0" -Make sure throttle EPA's are both set to 100% Let us know what happens (whether it works or not, please) PS, "Bergan" where?? Just curious. |
12-26-2012, 03:53 PM | #3 |
Nope, didn't work
12-26-2012, 04:00 PM | #4 |
Rock Crawler Join Date: May 2012 Location: Australia
Have you checked your settings via castle link? Maybe it's in forward only mode |
12-26-2012, 04:02 PM | #5 |
I checke.d that. Its in the default setting
12-27-2012, 12:43 AM | #6 |
try reversing the esc channel on the radio, then reprogram esc to radio, hope that helps.
12-27-2012, 06:48 AM | #7 |
I tried that too. Still didn't work.
12-27-2012, 01:38 PM | #8 |
make sure your trims are at 0, and epa are set to 100, also look into abs programming on the esc, not sure if the bxrl has it or not, just worth mentioning
Holmes Hobby br-xl won't go in reverse - Similar Threads | ||||
holmes hobby help | troy95chevy | Electronics | 3 | 08-24-2011 01:18 PM |
Holmes Hobby logo... | Unholy | Chit Chat | 18 | 11-18-2006 06:24 PM |
