01-01-2013, 05:58 PM | #1 |
Newbie Join Date: Sep 2012 Location: S.W Missouri
| Bec Install
I just finished installing a castle bec in my wraith RTR with a hitec 7980 is it normal to have the servo buzz or sound like static and when i turn the power switch off all it turns off is the esc lights and servo are still powered up thanks
01-01-2013, 06:08 PM | #2 |
Pebble Pounder Join Date: May 2010 Location: Ephriam, Utah
| Re: Bec Install
No...Try checking your Radio and it's settings. When it is buzzing Means it is running. So check out your radio and then Try it disconnected from the BEC.
01-01-2013, 06:36 PM | #3 |
Rock Crawler Join Date: Mar 2011 Location: hampton
| Re: Bec Install
i the servo hooked to the BEC,or is the bec hooked through the RX? if to the servo, it will have power whenever the battery is hooked up. so it can make some noise
01-01-2013, 06:47 PM | #4 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
| Re: Bec Install
My 7954 buzzes alittle bit. Especially if it doesn't completely go to center. I can wiggle the steering wheel and it will stop. You should always unplug the battery when not in use and not just cut the switch off. Run the bec to the rx in the battery plug. This way the rx is powered from the bec, but the lights will stay on as long as the battery is plugged in.
01-01-2013, 07:29 PM | #5 |
| Re: Bec Install This....if the BEC is direct from the battery to the servo, it WILL draw power regardless of whether the "power switch" is on or off.
01-01-2013, 07:37 PM | #6 |
| Re: Bec Install
Thanks for your help guys I went bec to rx batt cut red wire on esc servo to rx as per castle instructions was this not the best way to wire it
01-01-2013, 08:35 PM | #7 |
| Re: Bec Install
There is another way that would have been easier, though not necessarily 'better'. CreationFab and Holmes Hobbies both sell receiver bypass adapters that connect the BEC straight to the servo, the red wire wouldn't get cut, as it would supply the power to the receiver. I got bored outta my gourd tonight and went downstairs and built one. I wouldn't so much call it better, because although turning off my ESC did kill power to my receiver, interrupting the signal to the servo, the BEC was still providing power directly to the servo, so I don't think your buzzing would have stopped. I think you're stuck with that buzz whichever way you wire up your BEC. Going to have to get into the habit of disconnecting that battery. |
01-01-2013, 08:39 PM | #8 |
| Re: Bec Install
I do pull my pack every time I just wasn't sure if that buzz was normal or if i had a problem somewhere
01-02-2013, 04:48 AM | #9 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
| Re: Bec Install
On a digital servo, the buzz is normal with no input from the radio, it's the servo trying to find center which is why if you move the wheel some it may get quiet.
Bec Install - Similar Threads | ||||
How to install a BEC in a RS10?? | Big Pitt | Redcat Crawlers | 15 | 12-12-2010 08:52 AM |
Bec install | zignzag | Electronics | 11 | 11-13-2010 08:32 PM |
castle BEC install | bawghawg | Newbie General | 4 | 10-19-2009 11:59 AM |
In & Out BEC install | microgoat | Electronics | 3 | 11-19-2007 01:40 PM |
