01-02-2013, 09:54 AM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: Hollister, california
| Bec trouble, help please.
I'm running a axial ae2 esc hooked up to a tekin 35 t motor and a gens ace 500 mah 2s and i just hooked up my bec and now it doesnt work for some reason. I have tried to restart it but it doesnt work
01-02-2013, 09:59 AM | #2 |
Rock Stacker Join Date: Mar 2012 Location: U.K.
| Re: Bec trouble, help please.
I would check every new connection you made, and ensure that you removed the red wire from your ESC and check if your battery is fully charged. Also posting up a pic may help someone notice a problem you missed |
01-02-2013, 10:59 AM | #3 |
| Esc wire And battery wire |
01-02-2013, 11:00 AM | #4 |
I had this bec hooked on to a diferent car too and it worked fine
01-02-2013, 11:21 AM | #5 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
What's not working? Bec light even turning on? And needs shrink wrap..... Zero electrical tape.
01-02-2013, 01:33 PM | #6 |
Thanks and yes the bec lights up and the esc lights up and when i push full throttle is lights up red ( like normal ) and when i push full reverse it lights up green (like normal)
01-02-2013, 01:34 PM | #7 |
The servo works too, its just the throttle that just work.
01-02-2013, 01:43 PM | #8 |
It should light green forward and red in reverse. Sounds like your motor is wired backwards and you have the channel reversed on your radio to compensate although that's not why it won't work. Most of the time one of my rigs with an ae2 and CC bec will do exactly as you describe. It does it because my I don't run my radio with the throttle channel exactly on center. I'll pull a tiny bit of throttle and the speed control will go into its normal startup beeping and flashing light sequence again and away it goes. |
01-02-2013, 02:19 PM | #9 |
It wont even beep and i run a wraith so i run it backwards. And i will center my throttle trim and try to re-setup my esc and when i turn it on with the full throttle held it does blink or beep.
Bec trouble, help please. - Similar Threads | ||||
BRXL+Castle Link+Bec=? How do i set BEC? | crazyorigin | Electronics | 17 | 11-21-2011 03:11 PM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
BEC trouble | rideslow | Newbie General | 3 | 06-12-2008 12:05 PM |
Castle BEC trouble anyone.....? | TattooKenny | Electronics | 35 | 05-02-2008 05:04 PM |
DX7 + Mamba + Castle BEC = trouble | JohnRobHolmes | Electronics | 9 | 10-03-2007 08:23 PM |
