01-03-2013, 06:56 AM | #1 |
Rock Stacker Join Date: Jan 2006 Location: Okinawa, Japan
| Lipo help for an idiot
So I have done some searching and am still very confused. I would like to go lipo, but don't know how to go about it. What do I need to change, etc... I run the following set up, but am clueless about how to convert to lipo. http://www.teamnovak.com/products/es...bel_1000px.jpg |
01-03-2013, 07:19 AM | #2 |
Rock Crawler Join Date: May 2009 Location: Hillsboro, OR / Kapolei, Hi
| Re: Lipo help for an idiot
Looks like all you have to do is enable the Lipo cut-off and pick up a 2-cell (2s) Lipo batt. Other then that, its just a matter of how big of a Lipo you want/can fit. My general rule of thumb with Lipo batts is if you can afford the higher C-ratings, get as high as you can. Crawlers don't really pull high discharge currents, but if you decide to use the batts in a power hungry rig, you won't have to buy new batts. That just me opinion though. Study all you can about Lipo use. Best way to keep from fowling up. -B Oh, and don't forget that you'll need a Lipo charger and a charging bag. |
01-03-2013, 07:38 AM | #3 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
The Rooster is limited to 2S only. If you try to go to a 3S or higher battery you will fry the ESC. Like stated above just enable the #2 setup (lipo cutoff activated) and you are GTG. A decent charger with a balancing board will help tons and keep your batteries fresh for a long time if directions are followed correctly as far as charging, discharging, and storing your lipos at the proper voltages to increase battery life.
01-03-2013, 03:50 PM | #4 |
So are the connections on lipo batteries the same timaya connectors then?
01-03-2013, 03:59 PM | #5 |
Quarry Creeper Join Date: Sep 2011 Location: Lexington
| Re: Lipo help for an idiot |
01-03-2013, 07:00 PM | #6 | |
| Re: Lipo help for an idiot Quote:
01-14-2013, 06:14 AM | #7 |
Ok, so I am looking on there and have selected the Elite 850 7.4v 2S lipo pack. I know what kind of connector I need, but what is the balance connector? I assume that has something to do with the charger? Can someone please recommend a good charger for me. Also, I assume I should order a few batts at the same time...
01-17-2013, 07:13 AM | #8 |
Bueler....
01-17-2013, 08:14 AM | #9 |
Pebble Pounder Join Date: Feb 2009 Location: wilkeson
That seems kinda small!! The higher the MAH the longer the run time. I currently run a 2s 6000 and it last like 2 hrs!!! Good luck!!! |
01-17-2013, 08:16 AM | #10 |
The duratrax chargers are good and cheap.
01-17-2013, 02:01 PM | #11 |
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
How many and what type of vehicles do you have? How many will you have in 6 months? A year?
01-17-2013, 02:11 PM | #12 |
I only have 1 vehicle, ax-10 and that will be the only vehicle
01-17-2013, 03:12 PM | #13 |
Pebble Pounder Join Date: Oct 2012 Location: Graham WA
then the battery you stated should work fine if it has a decent enough c rating. Rooster ESC is a powerful ESC. I wouldnt go anything lower than 25c continuous. as thats what I have and have no issues. Lasts about 20 min a pack. |
Lipo help for an idiot - Similar Threads | ||||
Idiot With Lipo batteries... | K_B | Electronics | 9 | 09-25-2006 03:37 PM |
ok im a idiot | STANG KILLA SS | Newbie General | 5 | 06-01-2006 12:09 PM |
im an idiot... | lilcurtis | Newbie General | 8 | 11-09-2005 06:18 PM |
