01-03-2013, 07:15 PM | #1 |
Newbie Join Date: Jul 2009 Location: Westminster/Walhalla
| 12V Power supply
Ok, so i'm about to modify a PC PSU to run my charger but I was just looking at an extra power supply from my broken xbox 360 and the output is DC 12V at like 10 amps. It's connection to the xbox is through a 2 pin plug which I assume is + - so could I also use it to power a charger? Maybe a stupid question but I just thought i'd ask.
01-03-2013, 08:59 PM | #2 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
You could probably use it. I'm using a 16v supply from a satellite receiver dish and had a similar plug on it. I've also got a converted ATX psu that works like a charm.
01-04-2013, 04:38 PM | #3 |
| Re: 12V Power supply
Did some searching and found that it's a great simple PSU just for powering a charger. Gonna cut off the connector though and go with something else.
01-05-2013, 09:39 AM | #4 |
Newbie Join Date: Dec 2012 Location: Volusia County
I use my 25A power supply for my amateur radio setup. I have Anderson Power Pole connectors on it, so I just fitted my charger with the PP's as well, so I can plug it in at the house or in my Jeep. Funny thing is the charger has a 120V transformer built in, but I haven't even used it yet.. Probably won't either.. |
12V Power supply - Similar Threads | ||||
Modding a PC Power Supply into a 12 Volt Supply for your DC charger | TwistedXT | Electronics | 166 | 05-22-2019 07:28 PM |
Cheap 12V 32A power supply | autoper | Electronics | 1 | 05-14-2011 06:19 PM |
DIY 12v DC 20 amp power supply | BeadLock | Electronics | 11 | 09-28-2005 07:40 PM |
