cheap servo? i am looking for a chepo durable high tourq servo? any recomendations?"thumbsup" |
Re: cheap servo? Solar d772 is probably best price/oz durable.... I dont know. I run hitec, jr, futaba and just grabbed a few 500oz savox with good luck so far |
Re: cheap servo? I'm running a Solar D772 on my Ridgecrest with a 5A BEC on 6V. Seems to work pretty good, although I think the specs are a bit over rated (see the reviews on the Hobbypartz site). Haven't had a problem with it yet. |
Re: cheap servo? i run a few of the solars, for 18 bucks, there not bad |
Re: cheap servo? what rig are you running it in? the hitec 645 or 5645 are about 30 bucks and about 130 -170 oz of torque. |
Re: cheap servo? I've got a HobbyKing servo on the way, based on the specs its rated at 430oz/in @ 7.4v. Once it gets here I'll post up about it. |
Re: cheap servo? +1 on the solar D772 its a great deal for the price, i just ordered three more and they arrived yesturday |
Re: cheap servo? Quote:
Mi Digital HV High Torque Metal Gear Servo 31kg / 0.15 / 60g |
Re: cheap servo? I had seen a conversations that the hobbyking had very common failure of bending the pins. Hope you have better luck cause the specs are there for sure! |
Re: cheap servo? thats not the one i had.i had a orange case one |
Worst case, I'll see if Gunnar can make me some replacements. "thumbsup" |
Re: cheap servo? Get the turnigy 1501 from hobby king very strong only $12 and I have had the same in my trucks for over a year no problems! I believe 230oz .12 speed at 6 volts |
Re: cheap servo? Running the D772 here powered right off the lipo. Never wanted 'more' servo while using it. |
Re: cheap servo? get the best you can afford , going cheap isn't allways the best choice |
"Good" sorta depends on what rig & what use. What is good in a 1.9 for fun/trail runs is NOT good for a Super in comps. Fun/trail rigs and lighter scale rigs can get away with servos under 200inoz, 1.9 comp rigs are looking for ~200inoz+ and 2.2 comp rigs are looking at 300inoz+ and an external BEC. So, a statement of, "I want a cheap servo" is sorta useless. Is a $10 servo that dies in the first run worth it?? [likely - no] On the other hand, is a $180 servo in a 1.9 trail rig worth it? [likely no, unless you have money to burn] |
Re: cheap servo? i've been lucky with cheap HK servos. For the price their tough to beat honestly ... HK15298B High Voltage Coreless Digital MG/BB Servo 66g / 20kg / 0.16s |
Re: cheap servo? savox1231mg 444 oz torgue 74.99 amainhobbies |
