01-05-2005, 11:26 AM | #1 |
Rock Crawler Join Date: Dec 2004 Location: www.ORCRC.com
| Motor Break in Procedure & Reasons Why
Well I'm just a Noob when it comes to the land of RC vehicles and I never hear of this before until SR5Dave mentioned it in another post. So why do you break a motor in? Are you causing any harm if you didn't? What methods are used to break a motor in? This was SR5Dave said in another post. Ref: http://www.rccrawler.com/posts5293-0.html If the motor arcs in synch with the radio glitches, I'd suggest breaking the motor in on less voltage. (Do the underwater on 7.2V trick)..... Breaking in the motor: Pull your motors out, plug them into a 7.2V pack, and run it underwater until it stops spewing out crud (no more than 1-2 minutes I'd imagine). And no, water won't hurt a thing (I can't remember how many volts until things arc under water, but its like 25+) So RC motors are fine underwater What this does is it lets the brushes on the motor get ground down so they make full contact to the comm (thing brushes ride on).......Its the crud in water that screws things up! Water itself is fine. |
01-05-2005, 11:31 AM | #2 |
| Re: Motor Break in Procedure & Reasons Why
Oh this is the only reference I found for motor break in here on RCCrawler.com..... http://www.rccrawler.com/postlite4333-motor.html+break |
01-05-2005, 11:31 AM | #3 |
Rock Crawler Join Date: Apr 2004 Location: Longmont, CO
The idea is to set the brush (wear the contact in with the commutator) with less current so when ya run it normally the current has more surface area to transfer the power to the comm. Personally, if I had a nice motor to race with I might break it in but with nice soft silver brushes. For a lathe motor, I really wouldn't bother cause they don't draw many amps anyway. Never a bad idea, but I've never broken in a motor in a crawler. |
01-05-2005, 11:46 AM | #4 |
Newbie Join Date: Oct 2004 Location: Yakima, WA
| Re: Motor Break in Procedure & Reasons Why |
01-05-2005, 12:12 PM | #5 | |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| Re: Motor Break in Procedure & Reasons Why Quote:
01-05-2005, 12:55 PM | #6 |
Good point. IF your crawler weighs 20 pounds and your running lathe motors on 110VDC you best break them in nice |
01-05-2005, 01:41 PM | #7 | |
01-05-2005, 03:24 PM | #8 | ||
Okay so did I do any damage to mine that I should be concerned about. Or should I tear it apart and polish the Communicator/arbor shaft thingy? | ||
01-05-2005, 09:05 PM | #9 |
I didn't know you were an ME... I am an ME in training I'm sure they're fine, I doubt you did anything to hurt em. They may be broken in now already just from running them. Its less than ideal, but oh well. |
01-06-2005, 09:18 AM | #10 |
Yeah, thats what I'm thinking...... probably to late now to get any benifit from it. Offically I got a BSME in '98. So does that mean I have a degree in B*LLSH*T'N myself, maybe..... |
01-06-2005, 10:55 AM | #11 | |
