06-22-2016, 10:07 AM | #21 |
RCC Addict Join Date: Apr 2011 Location: San Diego
| Re: Another servo winch building tutorial Locked up RC. RPP carries the Locked up spools as well Welcome to Locked Up RC - Scale Performance Parts |
12-29-2016, 10:46 AM | #22 |
Rock Stacker Join Date: Nov 2016 Location: Cornwall, England
Hello. I know it's a bit cheeky but know anyone making winch controllers in the UK?? Or do you ship to here??
12-29-2016, 10:48 AM | #23 |
| Re: Another servo winch building tutorial |
05-22-2017, 09:55 AM | #24 |
Newbie Join Date: May 2017 Location: Fairfax County
Wow this thread has been so helpful. Thanks One question. If I want to use a SCX10 ii in scale competition what should I use for the dummy winch? I assume one would have a dummy winch mounted on the front bumper then have the line go through the flairlead and winch then to the servo winch on the chassis for the actual pulling. I have searched for winches but they are all wired for pulling |
05-22-2017, 09:59 AM | #25 |
You're welcome! Maybe someone else can suggest what can be used for a dummy winch? Maybe use a scale winch until it breaks, or buy one and remove the motor and give it to a friend that needs a new motor in their scale winch. |
05-22-2017, 10:30 AM | #26 |
Pebble Pounder Join Date: Jun 2011 Location: Finland
Shapeways has an 1:10 Warn 8274 Needs to be painted though...
03-18-2018, 03:11 AM | #27 |
Rock Stacker Join Date: Sep 2015 Location: Rancho Cucamonga
Are you able to fix the pictures on this thread? It is not showing up anymore.
03-18-2018, 06:32 AM | #28 |
03-19-2018, 11:34 AM | #29 |
03-19-2018, 11:36 AM | #30 |
Thank you!
03-19-2018, 11:40 AM | #31 |
Rock Crawler Join Date: Nov 2014 Location: Dells
DO NOT use the powerhd 20kg servos with the wireless winch controller, they cause enough interference to mess with the winch controller.
03-19-2018, 12:59 PM | #32 |
I've replaced the missing pictures in the first post and changed some of the wording to hopefully make a little more sense.
03-19-2018, 01:25 PM | #33 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
03-19-2018, 01:51 PM | #34 |
03-26-2018, 10:41 AM | #35 |
10-26-2019, 11:13 AM | #36 |
Rock Stacker Join Date: Mar 2019 Location: Bothell
Newbie question... I assume I still need a controller even if I start with a 360 servo?
10-26-2019, 11:27 AM | #37 | |
| Re: Another servo winch building tutorial Quote:
Also, see if it will hold something up when you aren't commanding it to turn. The winch controllers I make have an electronic brake feature. It helps to stop the winch from unwinding when it has a load on it. Of course, it can be overpowered, but it helps. Do the electronics in the 360 servos do that too? I really don't know. | |
Another servo winch building tutorial - Similar Threads | ||||
Jevne Batt./Servo Plate With Servo Winch Installed? | BodiBuilt | Axial SCX-10 | 0 | 12-11-2012 05:19 PM |
Building a wiper motor servo?? | Bart bender | Electronics | 5 | 06-03-2009 02:04 PM |
