01-06-2013, 10:18 PM | #1 |
Pebble Pounder Join Date: Feb 2012 Location: Newfoundland Canada
| How do I run LED's from a 9volt battery
Hey there generally im new to installing LED's. I want to install a light kit and run it off a 9 volt battery, can anyone post a link or perhaps explain how i would do this. The light kit i ordered is this one....1set G T Power 12 LED RC Car Flashing Light System | eBay Also how would I go about running off AA as an option? |
01-07-2013, 04:13 AM | #2 |
Pebble Pounder Join Date: Apr 2012 Location: Apple Valley MN
| Re: How do I run LED's from a 9volt battery
The set you ordered won't run off of 9v (specs show 4.8-6v). Looks like you just plug it into your receiver for power.
01-07-2013, 10:54 AM | #3 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
If for some reason you don't want to or can't power if from your receiver, you could use a receiver pack.
01-07-2013, 11:27 AM | #4 |
Other Options: 1) 4 AA alkaline cells in series. Radio shack sells a battery holder that would work. RadioShack Enclosed 4 AA Battery Holder : Battery Holders | RadioShack.com 2) You could a add a BEC programmed for 6V if you can't power it off the receiver. |
01-07-2013, 02:44 PM | #5 |
wire up the LED's with the proper resistors, get a 9v plug from radio shack, solder + to+ and - to - on the 9v plug and then just hook up the 9v batt. check the back of the LED package & make sure they are the right voltage and your good to go. I have used up to 10 LED's with this set up but prefer running it thru the RX. these used to be run by a 9v batt. Last edited by crawlhog; 01-07-2013 at 03:07 PM. |
01-07-2013, 04:12 PM | #6 |
Aren't 9V batteries kind of expensive? Why use one when you can run from receiver power?
01-07-2013, 04:39 PM | #7 |
Quarry Creeper Join Date: Feb 2009 Location: Ukiah
9V batteries have a very low capacity (they won't last long). Here is our AAA battery holder that would work great: Gear Head RC 4 AAA Battery Holder with Switch -Jim Rpp Hobby/Gear Head RC |
01-07-2013, 05:08 PM | #8 | |
| Re: How do I run LED's from a 9volt battery Quote:
01-07-2013, 05:10 PM | #9 | |
True they are, I was also looking for a AA battery holder to use, thanks to previous post I can get one..... The reason I dont wanna run thru receiver power is I like to switch around my bodies on different chassis ( i have 2 scx10's and a trail finder) sometimes I switch bodies around. | |
01-07-2013, 05:19 PM | #10 | |
No need to buy a battery pack or extra batteries as you are going to run it from your chargeable that runs your rig! | |
01-07-2013, 06:08 PM | #11 | |
Well to get at my receiver i have to remove battery, remove battery tray, then open receiver box (3 screws) and then do that in reverse. Ill get one of those 4 AA holders, i use rechargable AA's in everything, beats buying new batteries every few days. | |
01-07-2013, 06:20 PM | #12 |
Rock Crawler Join Date: Jan 2006 Location: Phoenix
you could also get a servo extension for each truck run it outside the box and just unplug the lights at the extension, no need to keep opening the box to unplug the lights
01-07-2013, 11:07 PM | #13 |
| Re: How do I run LED's from a 9volt battery |
01-08-2013, 12:52 PM | #14 |
Quarry Creeper Join Date: Oct 2009 Location: Athens
Been running the type of system you describe for a few years now on my drift RC cars. Like you i got tired with having to plug and unplug the wires every time i removed the shell. I also had problems as there needed to be a certain length for me to be able to get my hand under the shell to disconnect them, but if i went slightly too long the wires got caught around my drive belt, if i went too short it was a right faff to get my hand in every time i removed the shell. So i used some velcro on the shell and a PP3 9v battery, soldered a PP3 connector to the LED's and have been running that. Didn't bother with resistors as i wanted to keep it simple, figured if i have to replace a LED that cost very little money once every 3 months then i'd be happy with that. As it is i've been running like this on the Elise shell for around 3 years and around 2 1/2 years with the 350z shell and i've not had to replace a LED yet. I get just over 2 hours out of a 155mAh LSD type rechargeable PP3, which is about the time it takes for me to start getting bored. If i want to drive for longer i simply take an extra PP3 battery. Looked at using AA batteries, what put me off though was, my PP3 weighs 30g with velcro. 4 x Eneloop's weigh just over 100g, you need to add the weight of the holder to that as well. So i didn't want all that weight high up above the CoG and was prepared to replace LED's as a compromise, as it turns out they still seem to run for hours and hours even on just under 9v Here's my set up's on 2 of my shells. The Elise runs front and rear lights together with a controller, the 350z just front lights. Cheers Mark |
01-09-2013, 06:16 AM | #15 |
Rock Crawler Join Date: Mar 2011 Location: hampton
i run mine off a old cell phone battery, very small,very light and god knows how long they will run off it i soldered a jst plug onto a couple old batteries |
01-09-2013, 05:20 PM | #16 | |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
Sent from my GT-I9100 using Tapatalk 2 | |
How do I run LED's from a 9volt battery - Similar Threads | ||||
How many LED's can I run off of an RX? | RNUOVR | General Scale Talk | 5 | 12-02-2011 03:53 PM |
What battery to run? HELP! | losimini760 | Electronics | 6 | 05-16-2011 12:47 AM |
battery run time losi battery | perez62682 | Team Losi Comp Crawler | 4 | 03-14-2010 08:22 PM |
Finally MY LED's ARE WORKING!!! over 26 LED's | 4x4Crawler4LIFE | Scale Videos! | 11 | 07-28-2009 09:07 PM |
How do you run 1 battery for CC | SDheavymetal | Duratrax Cliff Climber | 3 | 12-25-2008 03:29 PM |
