01-07-2013, 10:17 AM | #1 |
RCC Addict Join Date: Jun 2010 Location: fort collins
| servo winch?
Is there a reason you need to set the pot and not just remove it. I am not finding any reason or info saying it wont work to remove it and bypass it. Need help understanding this. Thanks |
01-07-2013, 10:36 AM | #2 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| Re: servo winch? You can remove it if you are using an aftermarket winch controller. If you are using the stock servo board you need to center the pot to take the creep out and glue it. I prefer taking everything out of the servo winch and using a relay servo winch controller since you can feed it with 12 volts and get alot more power and speed. With the stock electronics (on a Hitec 645 or 7955) you are limited to 6 volts.
01-07-2013, 10:50 AM | #3 |
| Re: servo winch?
I under stand that but funds are not available right now for a winch controler. I really want one but I have to work with what I have. I centerd the pot and glued it but I still get drift so I was wanting to know if you take the pot out if it will get rid of the need to set it. I was not sure if that is possible or if the pot is just a needed part of the electronics. I think the next option I have if removing the pot is out is just putting a off switch to kill all the power to the winch when not in use. thanks, more info would be great |
01-07-2013, 11:26 AM | #4 | |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
| Re: servo winch? Quote:
01-07-2013, 12:06 PM | #5 |
| Re: servo winch?
Ok thanks. Just didnt know you needed to resisters to eliminate the pot..
01-07-2013, 12:29 PM | #6 |
| Re: servo winch?
Yes, you need the pot or the resistors. The problem with the winch drift isn't caused by the pot / resistors changing value on you. It drifts because you have a high gain amplifier (the servo amplifier) and you aren't giving it any feedback in proportion to its position. The transmitter signal and or the components in the servo amp all change value slightly with temperature or how you look at them and the servo amp sends power to the servo motor to correct for this change... but the feedback loop - the rotary position information from the pot - has been defeated, so the winch line will creep on you. As was pointed out, you can put a toggle switch on the positive or negative line feeding the servo winch and just turn it on as needed. If you have a few bucks, get one of my controllers instead |
01-07-2013, 12:37 PM | #7 |
| Re: servo winch?
Heyok, thanks for the insight on this. I will be getting the winch controler but I have been out of work for a month so funds are being saved until I start working again. Just trying to figure out the best/free fix to get me by. Thanks again
01-07-2013, 12:49 PM | #8 |
Quarry Creeper Join Date: Jul 2012 Location: Alpharetta, GA
| Re: servo winch?
Just built a winch for my Bronco using one of the HeyOK controllers. Played with it this weekend and it works great!
01-07-2013, 01:56 PM | #9 |
| Re: servo winch? Cool. Save your money, the toys can wait. Take care of the important stuff first!
servo winch? - Similar Threads | ||||
Jevne Batt./Servo Plate With Servo Winch Installed? | BodiBuilt | Axial SCX-10 | 0 | 12-11-2012 05:19 PM |
Which servo for a winch? | PIMPNROCKS | Newbie General | 4 | 07-07-2008 01:07 AM |
