01-07-2013, 11:05 PM | #1 |
Rock Stacker Join Date: Feb 2012 Location: Cororan
| VXL motor heat problems in wraith
Okay so i have a vxl motor it has had heat problems i. The past when it was in my rustlet but now it is in my wraith as a new crawler motor well rock bouncer and im running a 16/90 gearing in 2wd and it got hot
01-08-2013, 12:36 PM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
| Re: VXL motor heat problems in wraith
check the gear mesh an or look for bindin in the drive train
01-08-2013, 03:55 PM | #3 |
Newbie Join Date: Aug 2012 Location: saline
Gearing or gear mesh. I had 17/52 racing in a strc slash 4x4 and only had small heat issues a fan and heat sync helped with itit
01-10-2013, 12:30 AM | #4 |
Well I think if I run the vxl I will just destroy it I think the vxl just runs hot
02-18-2013, 12:36 AM | #5 |
Newbie Join Date: Feb 2013 Location: BONITA SPRINGS
i got 87 20 in mine n its runs a lil warm cheak ur bearings n gear mesh
02-18-2013, 08:56 AM | #6 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
I run a vxl in mine and use 9/60 32p gears. I have the fan and mounted in the rear for airflow. I also took out the interior to help cool the motor. I run cut boggers without issues. Almost ZERO cogging and i can still touch the motor after some hard bashing. As long as you aren't comping it, I think it's a great basher setup.
VXL motor heat problems in wraith - Similar Threads | ||||
Heat problems!!! | XJkid93 | Axial XR10 | 21 | 02-27-2012 05:32 PM |
vxl-3s esc and 3500 brushless motor problems | diggindeep | Electronics | 16 | 10-11-2011 12:17 PM |
lcc heat problems | deboo | Team Losi Comp Crawler | 26 | 12-07-2010 10:27 PM |
