01-08-2013, 02:41 PM | #1 |
Pebble Pounder Join Date: Sep 2012 Location: Ljubljana, Slovenia
| MMP sensor broken/not working
i bought an used MMP from a guy , all looks solid , but the sensor port on it does not work. in sensored mode it cogs badly i did the recalibrations with TX, tried with two different ones. i've checked it with two different motors which work in sensored mode just fine on a different esc i've tried two different sensor wires which again work with a different esc. i've tested the pins of the mmp sensor port with a multi meter so that works as well , even tried it with a sensor cable attached and checked the pins , also contact. also the motors run if i set the mmp in sensorless mode itself. so it must be the esc itself. do i have any other options than sending it to castle for repairs ? its used so the warranty is not transferable , even if it were in warranty. only other option is to hope the guy gives me a refund or some money off the price so i can just use it with a brushed motor until i save up for a new mmp. any help is appreciated . |
MMP sensor broken/not working - Similar Threads | ||||
BL Sensor Cables | JeremyH | Electronics | 17 | 12-14-2010 08:38 PM |
Im Working On A Working Wrecker Any Ideas? | LEDDPIPE | General Scale Talk | 7 | 12-13-2006 11:53 PM |
